3rd Gen Dash Pad help!!!
Old Nov 15, 2003 | 08:48 AM
realMcCoy's Avatar
Car: 92 camaro RS
I finally got another Dash pad for my 92 camaro. My old one had about a 1000 cracks.
What can i do for this one to keep it from cracking? Is there some type of cleaner or oil that will help keep it from cracking?
Old Nov 15, 2003 | 10:07 AM
kerryismygirl89's Avatar
Car: 1989 Firebird
Engine: LB8 (2.8L V6)
Transmission: MD8 (Auto)
I've heard DO NOT USE the armour all stuff. I've heard that's very bad.
Maybe you could get one of those sun blockers to keep the sun from hitting it?
Old Nov 16, 2003 | 04:33 PM
onebinky's Avatar
Armorall will dry out all the natural oils of plastic and rubber, so if you ever stop using it the plastic will crack and fade really bad. I've always cleaned mine with windex, and I've never had any trouble with it. It also won't blind you on a sunny day
Old Nov 17, 2003 | 06:03 PM
Dean92RS's Avatar
Car: surprise!! a '92RS!!!
Transmission: 5 speed "M39"
NO SILICONE!!!
Whatever you do, avoid anything with silicone in it. That's what dries out the oils in vinyl.
I believe Meguiars puts out a couple of silicone-free vinyl/leather conditioners. Their line is numbered ("#3 Yellow Wax", et al), but I don't know which number is the best for your purpose.
Check around a few of the detailing websites for exotic and classic cars, I'll bet you find a lot of info.
HTH.
Old Nov 18, 2003 | 07:55 AM
ss85tadude's Avatar
Car: 85 Trans Am
Transmission: 700-R4
So have I messed up by using Armour All or if I stop now can I still save it, It is in mint condition.
Old Nov 18, 2003 | 09:23 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
You have'nt messed up, just in the future switch over to a different conditioner/cleaner.
Old Nov 18, 2003 | 01:23 PM
realMcCoy's Avatar
Car: 92 camaro RS
Thanks all of you, I bought the Meguiars stuff. However I now have a BIGGER problem. When I left the parts store I felt a stumble on take off and then all hell came out. It now backfires out the intake and has no power. I'm guessing my timeing chain jumped, but I have not got up the energy to find it out.
Old Nov 18, 2003 | 02:30 PM
IHI's Avatar
IHI
Run a quick compression test, it may be a simple as a stuck vavle-hate to see ya tear the front of the motor off before testing the simple things first
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
z28_AJ
Aug 27, 2015 08:59 PM
Vintageracer
Aug 11, 2015 08:13 PM
