Gas pedal question
Old Nov 18, 2003 | 04:29 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Gas pedal question
Yo,
I just need a GM part number for a stock gas pedal. That's it. I did a search first and found nothing. Thanks in advance...
After a little more searching, I have found that there may have been two different gas pedals used by GM. If anyone can supply either or both, that would be great...
Old Nov 18, 2003 | 05:09 PM
3gc's Avatar
3gc
Car: Z28
I'm pretty sure GM no longer makes one of the pedals, but i can't remember if it's the brake pedal or the gas pedal. Either way, i got both mine from nextgenparts.com It was only about $7 each.
Old Nov 18, 2003 | 08:00 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i just bought a set of ebay for 13 gas and brake pedal
Old Nov 18, 2003 | 08:20 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
I looked at nextgenparts and all I saw was pedal covers. I need the pedal itself, gas pedal. I will look again. Of course my best will probably be to go to the junk yard, but I don't have much time for that...
Thanks for the replies...
Old Nov 18, 2003 | 08:46 PM
3gc's Avatar
3gc
Car: Z28
Ah, for some reason i was thinking about the pedal pads.
Old Nov 18, 2003 | 08:51 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
lol so was i!! amazing all these third gen minds THINKING the same thing at once
Old Nov 18, 2003 | 09:40 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
You could almost say it was like a cult around here!!
Old Nov 18, 2003 | 11:30 PM
5SIZ's Avatar
Car: 1987 IROC-Z
junk yards all the way.
Old Nov 19, 2003 | 09:29 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have my gas pedal from my 86 Trans Am.
Make me an offer on it.
Old Nov 19, 2003 | 09:51 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I just bought a new one from Hawk's for like $10 or so. It was the second one used by GM. It is identical to the ones used in fourth gens. The difference between that and the original is the pattern on the plastic. Size shape and mounting holes are all the same.
Old Nov 19, 2003 | 04:15 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
The problem I had was I ordered a set of billet pedal covers from Thunder Racing. The clutch and brake fit just fine, look really good too. The gas pedal, does not even come close. When I took off the pedal to see what was going on, I realized I either needed a new gas pedal, or to do some serious reworking of the stock pedal to make it fit.
I think I will just go to a local junkyard and see if I can find one that fits.
Thanks for all the replies.
I do find it odd that GM would use two different designs for something like a gas pedal. Oh well, General Malfunction strikes again...
Old May 15, 2007 | 08:58 PM
83Chevy__Camaro's Avatar
Re: Gas pedal question
i have the part number for a gm stock one, i have a stock pile of them in my new gm parts collection going on my car, i just installed a new one today
Old Jun 7, 2007 | 11:41 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
How are the gas ped" held on?? By a torx or allen bolt?? all i have is a rod and nub at the end for my gas pedel lol, i have access to the orignal gas pedel on my other camaro, just wondering what ill need to swap it up.
Old Jun 8, 2007 | 04:37 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
That was my experience as well. Unworried about the stocker, I simply used a Dremel tool to cut the it down until the cover fit.
JamesC
A thirty pack.
1992 Trans Am
May 10, 2023 07:19 PM
redmaroz
Aug 16, 2015 11:40 PM
johanlindgren
Aug 16, 2015 12:16 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
