Rear Pull Down Hatch ?
Old Nov 25, 2003 | 10:42 AM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
can I put the pull down hatch motor from my 87 Z8 into my 88 IR0C-Z? I like that feature thnks
Old Nov 25, 2003 | 11:24 AM
hrddrv's Avatar
Car: 86 TA
Engine: 305 Carbed. Mainly stock Not running
Transmission: stock
I have never done it but I am pretty sure you could. Should be a direct fit.
Old Nov 25, 2003 | 11:36 AM
SHAGME's Avatar
Car: 1988 IROC-Z
well I Thought that the 4 metal contacts on the back hatch in the 87 need to be replaced with it? so the whole back piece should be replaced as well? and the back hatch? I cant remember if that has a contact? thnks
Old Nov 25, 2003 | 12:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The four metal contacts are not a part of the rear hatch pull down motor and the four metal contacts are only held in with two screws.
The Trickster!!!!!!!!!!!!
Old Nov 25, 2003 | 01:21 PM
SHAGME's Avatar
Car: 1988 IROC-Z
OK Tnks Trick. so then i just need to wire it up then I guess. thnks
Old Nov 25, 2003 | 05:19 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes you can use that 1987 pull-down unit in your 1988. The 1986-87 hatch pull-down unit has a large white connector on the blue wire which connects to the +12v red with white stripe wire. The 1988-91 has a smaller black connector on that same blue wire. You'll need to swap connectors. That is the only change you'll need to make in order to use it in your 1988.
It is a common misconception that the 4 contact pad has something to do with the hatch pull-down unit. It does not. From 1982-85 that pad was used to power the optional rear hatch wiper motor. From 1986-90 it was used for the HMSL (high mount stop light, aka third brake light).
Be sure to check out my web site under the "Hatch Pull-Down Items" category if you find that you need any parts to repair the hatch pull-down unit.
Lon Salgren
Top-Down Solutions
Old Nov 25, 2003 | 05:22 PM
SHAGME's Avatar
Car: 1988 IROC-Z
ok great thnks thats the ansxwer I needed thnks dude can u answer this ? for me too?
https://www.thirdgen.org/techbb2/sho...hreadid=211991
Old Nov 25, 2003 | 10:41 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
i assumed by the way you asked that question,,,it looks like your asking if you can take a hatch pull down off a car and put it on a car that didnt have it in the 1st place??? Is this tru, im not sure if you can do that. Can that be done anyhow Lon??
I have one for sale in classifides if it matters to anyoff you.
Old Nov 26, 2003 | 12:37 AM
lonsal's Avatar
That is not what he is asking. The powered hatch pull-down was standard on all F-bodies from 1986-90. So his 1988 already had one.
Lon
Old Nov 26, 2003 | 12:58 AM
Car: '81 Trans Am
Engine: 6.6L
Lon - thats what i thought but didnt know for a fact it was standard. Just cause he said it was a nice feature..I figured his other car was just a normal hatch latch like older 3rd gens. Or i guess someone could of made it a normal hatch latch cause they break alot i dont know??
Thanks tho
but is it possiable now that i think of it to put a hatch pulldown on a 3rd gen that didnt come with it??
Old Nov 26, 2003 | 07:14 AM
SHAGME's Avatar
Car: 1988 IROC-Z
No I dont have it on the 88 I have it in my 87 and want to put it in myu 88 IROC thnks
Old Nov 26, 2003 | 11:43 AM
lonsal's Avatar
The early style slam latch has a different mount. You'd have to cut the mounting from a car that had the electric hatch pull-down and weld it into the other body. Sound easy?, not to me. The late 1991-92 also has a different mount to the body.
Lon
Old Nov 26, 2003 | 12:20 PM
SHAGME's Avatar
Car: 1988 IROC-Z
bummer dude and thnkjs again
Old Nov 26, 2003 | 12:28 PM
lonsal's Avatar
Your 1988 already HAS the correct mounting to install the power hatch pull-down unit. I haven't seen a 1986-91 that doesn't. Pull out the plastic hatch surround trim and take a look. More than likely someone has converted the power hatch pull-down to a slam latch by welding or drilling then bolting the latch portion to the frame of the unit. All you'll have to do is undo the 3 mounting bolts and bolt in the 1987 hatch pull-down unit. Mark the location of the current bastardized unit first with a scratch awl or a permanent marker. It makes installing and aligning the new unit much simpler. Then you need to verify +12v at the red with white stripe wire. Also if yours has a powered hatch solenoid release, be sure to install the ground wire from the 10mm bolt to the grounding point below. Otherwise the solenoid won't work because the nylon guides are isolating the latch portion from ground source.
Lon
Old Nov 26, 2003 | 01:20 PM
SHAGME's Avatar
Car: 1988 IROC-Z
thnks man Ill lookat it 2 morro
Vintageracer
Jan 10, 2020 05:33 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
