Squeaks and bulbs
Old Nov 29, 2003 | 05:08 AM
D's89rs's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: Automatic 4
Squeaks and bulbs
First off, I have this very annoying squeak that’s coming from the driver side of the dash pad. It looks like it might be the dashpad vibrating against the A pillar. Any one have any ideas?
Second, while I had the dash apart to try to fix the aforementioned squeak, I noticed this tiny tiny light bulb under the dash, around the A/C outlet area, and a small clear plastic patch that would allow the light from the bulb to pass through into the center console area. I've searched the forums and people say it's an airbag light, but my Camaro is an 89, they didn't start putting airbags in until 90. What is it? Is it just another entry light with a burned out bulb? And if it isn't, could it be wired to something else (Alarm, shift indicator, etc. etc.)?
Old Nov 30, 2003 | 03:08 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
The light bulb is there to provide light to the ashtray, pretty weak if ya ask me though.
Kevin
Old Nov 30, 2003 | 04:32 AM
D's89rs's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Cool, I'm going to grab a new bulb then. I've got another question though. The bulb in the A/C control panel was out when I bought the car, so I finally (after about a year of having it ) replaced it. There only seemed one bulb on the right hand side of it. The right side of the panel lights up very well, but as it goes to the left, especially where the fan speed **** is, it is barely noticeable. Is there a second bulb I have missed or is it supposed to be like that?
Old Nov 30, 2003 | 05:52 AM
Engine: L98 350 TPI
There is only one bulb, sucks doesn't. I wonder if there is is anyone out there who has done an LED light conversion for the HVAC, like some have done for the gauges or if anyone has done anything custom in the HVAC??
Kevin
Fronzizzle
Feb 9, 2017 09:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
podiatra
Aug 31, 2015 09:53 AM
