i want to have green bulbs behind my guages. this post go here??
Old Dec 6, 2003 | 07:47 PM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
i just wnat to know what type of bulbs or any tricks i need to do. i want my guages to light up green when the lights r on. thanx
Old Dec 6, 2003 | 07:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just buy green colored #194 bulbs and put them in.
The Trickster!!!!!!!!!!!!!
Old Dec 6, 2003 | 08:27 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
More interior related, so I will move it.
A little help first though- since you have an 89, the black bezel that surrounds the gauges is what actually reflects the light onto the gauges. Stock, the back of it is painted a very light blue. If you really want the light to be green, I would recommend either getting green 194 bulbs and repainting the back of the bezel white or keeping the clear 194s and painting the back of the bezel green. I don't know which would make it greener, you may need to experiment a little bit to get the exact shade of green you are after. Good luck.
Old Dec 6, 2003 | 10:29 PM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
so i should paint the blue stuff green? I've taken all that off before but never noticed any blue. I'll take a look. thanx again. oh yeah and these 194 bulbs or whatever. where do i get them? to i just walk into advance or pep boys and be like i want 194 light blubs? lol never done anything like thios before
Old Dec 6, 2003 | 10:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, and they even sell them at Wal-Marts and K-Marts. Painting the blue stuff green I don't know about.
The Trickster!!!!!!!!!!!!!!!!
Old Dec 6, 2003 | 11:01 PM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
how many bulbs will i need? how much do they cost?
Old Dec 6, 2003 | 11:37 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
They come two to a pack and are about 2 to three dollars a pack depending where you get them and what brand name you get. You can knock off three for the turn signals and the hi-beam indicator and about four more for the ses, brakes, security, and seat belt. That should leave you about 13 to 14 bulbs.
Add 1 more if you want the AC/heater control panel to be green and another one if you want the shifter plate to be green.
The Trickster
Old Dec 6, 2003 | 11:42 PM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
how do i get to the shifter bulb and the blulb behind the ac panel?? that's kinda pricey. i've heard of some people painting their bulbs with transparents paint. ever heard of this?
Old Dec 7, 2003 | 12:10 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
To get to the bulb in the shifter plate, just remove the torx screws holding the plate down and lift it up. Bulb is at the rear of the panel, 1/4 turn and it comes out. AC/Heater control panel, remove face plate around radio and ac/heater control panel. Remove bolts holding control panel in bracket, slide panel out and bulb is at rear of panel on right side as you look at it. 1/4 turn and it comes out. Simple!!!!!
These bulbs aren't near as pricey as the ones that go in the third brake light mounted in the spoiler. They are about 7 to 9 dollars each and it takes about eight of them.
Old Dec 7, 2003 | 01:02 AM
MasterEvilAce's Avatar
if the back is painted light blue, couldn't he get yellow bulbs?
yellow + blue = green
Old Dec 7, 2003 | 08:37 PM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
master, but u'd think white and blue would be light blue too right? but for some reason the light is still white. i was thinking about that too.
yeah, i bought one of those 3rd brakelight bulbs and it was 6.50. i then discovered 6 were needed and not just one, so i dumped the idea. well thanx. 194 green bulbs is my new mission this week. thanx again
Old Dec 7, 2003 | 11:54 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
if u go to pepboys, look in the ***** isle, they will have different colored bulbs, from yellow, blue, green, red, purple. they should have most of those colors there enless there stock inventory is way off. i know this since i work for that stupid company.
Old Dec 8, 2003 | 08:00 AM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
it look like eveyone hates wroking there. all the people in there always look unhappy
Old Dec 8, 2003 | 01:32 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
there are 11 bulbs in your guages youll want to change...get 2 more if you want to replace your feet dome lights too. Yes all 13 of them are 194. I really like the color of the APC blue bulbs they seem to be nicer then the otherones i have bought.
Old Dec 8, 2003 | 05:36 PM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
ok guys, i just started the insalling of the green bulbs. they disapointed me. they are dim. not to mention i couldn't find a way to get the speedo/odometer guage off. there is a screw holding it in behind the guage face that i can't reach. any tips on either? i want my guages to be brighter.
JCurrier, since u chose blue, how did u get the clock to show blue also? thanx
Old Dec 8, 2003 | 07:25 PM
Car: '81 Trans Am
Engine: 6.6L
i got white face overlays and they are bright then. You cant be taking your cluster out right,,,because you should beable to remove only 2 screws and 2 nuts and pull your hole cluster out (this is after you removed the black plate w/ hex screws) The two screws are in plane view but the 2 nuts are inside one of those warning light tunnels. Also you may have to take your dash pad off to unplug your speedo if you have a cable drinin one witch im not sure i think you dont. The idea is to remove the whole cluster and you can then turn and pull out your bulbs from behind. Make sure all the bulbs are lighting up cause even one out can make your cluster dim....and dont forget you may have it turned down on the headlight switch. Make a set of white face guage overlays of buy a set youll get a brighter effect then the white on black. Cheack out the tech articals for a guide i think theres two here at the main page.
Oh yah i dont have a clock anywere in my car so i cant help ya there.
Old Dec 8, 2003 | 07:32 PM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
hey thanx. it'd almost seem easier if i just bought those white faced glow guage lay overs off of ebay. u heard any good or bad about them. i just wonder, if they glow at night, will the green lights i have behind the the guages effect the look of the glow? thanx
Old Dec 8, 2003 | 07:34 PM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
u should have the digital time on the stereo thing. that is unless u got a new deck.
Old Dec 8, 2003 | 08:32 PM
blackztpi's Avatar
Car: 89 Iroc Z28
Engine: 312ci
eBay item 2446806951 (Ends Dec-10-03 22:11:18 PST) - *CHEVY* 85~89 CAMARO 115MPH GLOW GAUGES IROC how do these glow guages look/ work?
Old Dec 8, 2003 | 10:29 PM
AFor89mula's Avatar
Look on ebay for 194 LEDs...they are quite a bit brighter.
Old Dec 8, 2003 | 10:47 PM
Abubaca's Avatar
I have eurolite blue/hyperwhite 194's in my guages and shift plate. they look AWESOME compared to the stock bulbs. They have that very light blue glow, but there a LOT brighter than stock, and that's what looks so good!
Old Dec 9, 2003 | 09:52 PM
KBeez's Avatar
Car: 88 Camaro S/C
Transmission: 700-R4
Couple Questions.....
Hey, so all one has to do is pop out their current cluster, and then replace all the current bulbs with blue ones and you get the blue guages? And the LED's are brighter/more effecient right? (and who online and offline sells the lcd's?)
Now, I have an '88 SC, with the 85 mph/kph speedo. Will this still work or even look good? And would I have to paint the bezel?
and anyone got any pics?
Old Dec 9, 2003 | 10:34 PM
Abubaca's Avatar
I changed nothing but the bulbs. Now, don't get me wrong, there still black faces, but they don't have the yellow look.
Old Dec 9, 2003 | 11:29 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
Anyone done the LED thing in the tech section with two LEds per socket with resistors on back? If so how do I know what resistors to use?
Old Dec 10, 2003 | 05:50 AM
Ryknow86's Avatar
Car: 84 Camaro Z28
Engine: carbed 350
you may also be able to go to walmart and get that "neon rope light" thats thin enough and route it around near the edge of where the gauges are.
Old Dec 10, 2003 | 04:35 PM
KBeez's Avatar
Car: 88 Camaro S/C
wait... from reading some other posts it sounds like putting led's in in place of the stock 194 bulbs is quite the chore. Is it all that hard?
And if it is, it looks like the best deal is to get a bulb with like 4-6 led's inside a stock fitting 194. Is that right?
thanks
Old Dec 11, 2003 | 08:39 AM
Topless91RS's Avatar
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
I am thinking of changing mine to red, whats the deal with the cluster of led's, is it a direct plug in or does some modifying need to be done??
Old Dec 11, 2003 | 11:38 AM
AFor89mula's Avatar
Its a direct plug in, I have a friend that has done it in his Chevy truck. He told me all of this after I already took my dash apart and put red bulbs in. Just make sure its the LEDs in the 194 socket. Also, the single LEDs and the clusters produce different types on lights. Some are concentrated and some disperse real well, depends on what you want.
Old Dec 11, 2003 | 04:40 PM
Car: 95 Z28
where can I buy those socket ones? I wanna do that... How Much are they?
Old Dec 11, 2003 | 05:57 PM
AFor89mula's Avatar
I see them on Ebay a lot...as far as at a store, i dont know...maybe a custom shop or something? Price varies too, depends on if you get 1 led, or like 4 in one socket. I'll be going that route as soon as my painted bulbs fade and start to turn pink!
Old Dec 12, 2003 | 08:46 AM
Engine: 305 (L03)
A friend of mine has a 2000 Grand Am GT and her gauges are red and look sweet and thats what i want to shoot for!!
Old Dec 13, 2003 | 12:01 AM
AFor89mula's Avatar
Red looks great! I did the red bulbs and it looks very mean. I need the LEDs, but those will have to wait.
Old Dec 13, 2003 | 02:18 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
http://www.superbrightleds.com/1157.htm
Get the green 194 LEDs. I bought the blues and they are great. Get the 4 led 194s.
Brian
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Sep 6, 2015 10:42 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
