Speedo Problems
Old Dec 22, 2003 | 11:39 AM
350IROCconv's Avatar
Speedo Problems
I swapped my drivetrain out to a 1991 Z-28. The dash is out of a 91 RS. I've got a 1991 Z-28 140 cluster in it. For some reason the speedo is like 10 off. Any ideas?
Old Dec 22, 2003 | 12:04 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
did you swap trannies? if you took a tranny out of a car with diff rear gears your speedo will be off. Im in the midst of a dash swap and will have a very inaccurate speedo. Im gonna try dakota digitals calibartir thingy thats like 75 bucks. Check their website for info. Im gonna make a post in the product review board for anybody whos used one of those.
Old Dec 23, 2003 | 03:23 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
why not just swap the speedo gears in the trans that match the correct rear?
Old Dec 23, 2003 | 03:56 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
he could do that, but unless the gear in the transmission itself is changed there will be some innaccuracy.
if you do just use the old speedo gear to match your rear, count the teeth on the removable gears on each tranny (or they might have a number printed) and the difference should be your inaccuracy, if ive been correctly informed (the guy whotold me this worked at aamco, but this was accurate on my car when i swapped trannies)
Old Dec 23, 2003 | 04:29 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
its pretty easy and less $ to change both the drive gear in the trans and the driven gear. Then it should be accurate. try here. http://sethirdgen.org/vss.htm
Old Dec 23, 2003 | 04:52 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
holy crap, that article is extremely helpful, they list the part numbers for exactly what i need! I didnt think i could get 3.73 electric speedo gears for a 700r4 from gm. That means i dont need that dakota digtal thing. Thanx for posting that.
Old Dec 23, 2003 | 05:50 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I too would like to thank you for that site...
Your avatar pic is GREAT
Old Dec 24, 2003 | 11:40 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Good luck if you have an electric speedometer. I changed gear ratios and now my speedo is off. I was told by my local GM dealers that the speedometer gears I want are discontinued. Every other place I searched like: SLP, Third Gen Resource and Bowtie Overdrive all advertise gears for 700r4 electric speedometer but told me they dont carry the parts when I tried to order them. I plan to try the Dakota Digital electronic ratio adapter since it is the cheapest solution I found so far.
Old Dec 26, 2003 | 10:52 AM
Thanks for the help hopefully I can get it to be accurate.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
