C&C T=top headliner
Old Jan 11, 2004 | 01:06 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
C&C T=top headliner
So what do people with the C&C t-tops do for a replacement headliner? Revamp the stock one? Make your own? Ideas would be welcome...
Thanks,
Old Jan 11, 2004 | 01:14 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You can get a hard top headliner & trim it to fit.thats what i did with my C&C t-top dilemma.
Old Jan 11, 2004 | 01:24 AM
Engine: LS3
Transmission: 6L80E
Like a cardboard one or ABS? Then cover it yourself?
Old Jan 11, 2004 | 01:28 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
that or an original.i used an original H.top one & just trimmed it to fit.Later on i bought some replacement velour.Since the H.top liner was grey & my int is black.......
Old Jan 11, 2004 | 09:59 AM
Engine: LS3
Transmission: 6L80E
The material is coming away from the headliner, so I will have to just take it all down coming up and evaluate...
Thanks,
Old Jan 11, 2004 | 11:49 AM
kerryismygirl89's Avatar
Car: 1989 Firebird
Engine: LB8 (2.8L V6)
Transmission: MD8 (Auto)
Thanks,
If your board's good, you should just be able to recover it. And, if the headliner's not sagging too badly, you might be able to just glue up the part that's coming apart.
Old Jan 11, 2004 | 01:19 PM
Engine: LS3
Transmission: 6L80E
Unfortunately, a lot of the material is drooping...I will have to pull it down coming up to verify, but it takes a backseat to finishing the engine install, the front suspension upgrade, the C4 brake upgrade, and the rear suspension upgrade along with the new fuel pump
I have the parts, just need to make more time...
Old Jan 11, 2004 | 08:50 PM
D's89rs's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: Automatic 4
I've got the same arabian nights thing going on in my Maro. Above the material there is this nasty yellowish orange stuff that flakes off. Is that the board? And if it's not, can that stuff be replaced?
Old Jan 11, 2004 | 09:14 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thats probably the fiber type board that the velour is glued to.It comes apart fairly easy if exposed/touched/bent/etc.....
Old Jan 12, 2004 | 06:47 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Mine was broken by the seat belts, i used hot glue, and strips of carboard, fixed it perfectly
morrow
Jan 13, 2024 12:29 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
