Can someone tell me how to change the window sweeps?
Old Feb 17, 2004 | 09:51 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Mine still work but are cracked as heck, and I think it would clean up the apearance of the car a bit. I don't have any experiance at all with weatherstripping, so I have no idea how the stuff is on there (I'm guessing its glued?), how to get it off, and how to get it back on. Thanks.
Old Feb 17, 2004 | 10:31 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
Are you talking about the outer one you can see where the door meets the window? I need new ones too (less water gets in the door good to keep it from rusting common problem) they seem to be expencive tho.
I think its screwed on you have to remove your doorpanel and cap and rol the window down...if it is screwed youll have to losen the bottom stop and get the window to come down some more.....can anyone else verify if im right i may be getting confused with a different car.
Old Feb 17, 2004 | 10:50 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Yeah I need the outer one, the inner one is fine. I guess I have to just take it apart and find out. Someone got them for $45 from a dealer, thats not bad. And someone on ebay has them for $54, but I don't know how good they are.
https://www.thirdgen.org/techbb2/sho...hreadid=161045
Old Feb 19, 2004 | 01:56 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Remove the door panel and roll down the window. Its not easy, but not super hard,Just time consuming. Off is easier than the re-install. Some of the screws can be reached with a socket, others will require the use of an open end wrench. I replaced mine when I had my car repainted and what a difference it made against fresh paint.
Will
Old Feb 19, 2004 | 01:59 AM
norcalz28's Avatar
Also forgot to mention it helps if you remove the window adjusters, with the felt pieces on them. This will allow you to move the window forward and back to get some play..
Will
Old Feb 20, 2004 | 02:18 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
whats the part number for that ?
Old Feb 20, 2004 | 07:28 PM
3gc's Avatar
3gc
Car: Z28
I got new ones from GM partsdirect, they were $20+shipping each. I haven't gotten to putting them on yet because the paint isn't done. But i took a look and on one of my doors (from an 89) it's held on with a hex head screw, on my other door (from an 84) it's held on by philips head screws.
Old Feb 20, 2004 | 07:40 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
20 plus shipping? Thats cheaper than I have ever seen them, please share the part number if you have them
Old Feb 20, 2004 | 08:22 PM
scott's85T/A's Avatar
mine were held on with philips head screws too, some of them are a pain in the but to get to. Gave about $35.oo each for them from the dealership.
Old Feb 20, 2004 | 08:46 PM
3gc's Avatar
3gc
Car: Z28
10124264 - RH
10124265 - LH
$19.63 + shipping each
Comes to $52.46, about $15 less then buying it from the dealer.
Old Feb 21, 2004 | 12:04 PM
Car: '81 Trans Am
Engine: 6.6L
is gm parts direct on the net or just phone...do they ship to canada as with the us dollor down its still about 20-30 bucks cheaper for me to order them from the states instead of getting them at my dealer. the dealer wants 56(can) for one.
Old Feb 21, 2004 | 02:11 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
www.gmpartsdirect.com
Not sure about canada.
Mine are now postponed as of last night pending what this dam speeding ticket is going to end up costing me
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
evan555222
Sep 20, 2016 02:51 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
