Drain plugs
Old Feb 26, 2004 | 04:49 PM
89_305TransAm's Avatar
Car: '89 Firebird Trans Am WS6
Engine: 305 TBI (L03)
Drain plugs
Can you guys tell me where there are drain plugs/holes in the body? I think i remember reading there is one under the pass side rear seat but could someone chime in and confirm that and if there are any others? I need to run a wire through for my elec cutout.
Or better yet, where do you guys with elec cutouts run you wires through? I have a auto trans.
thanks!
Old Feb 26, 2004 | 05:28 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There are 5 drain points in your car. two at the lowest point in the front seat (foot) area, two at the lowest point in the rear seat area (foot area), and one at the lowest point in the cargo area. And these are big holes.
Old Feb 26, 2004 | 06:42 PM
Thanks alot man! I searched and this topic didnt seem to be covered before..also is it just some kind of plastic plug that i can take out or what? Never seen them before, but then again never looked for em.
thanks alot
Joe
Old Feb 26, 2004 | 06:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, they are metal plates several inches wide and long that are slid in place over the holes and then sealed with a thick sealant to keep moisture out. If you ever pull your carpet out, you will find the jute insulation stuck to the sealant.
Old Feb 26, 2004 | 09:05 PM
So you think it would be a good idea to pull up the cover and run a wire through and then seal it shut with something or two find another point of entry?
Old Feb 26, 2004 | 09:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Door # 2 = Find another point of entry. What application is your electric cut-out going to be used for.
Old Feb 28, 2004 | 12:31 AM
umm its a cutout..its going to open the QTEC on my cutout..? im confused by that one..lol
Old Feb 28, 2004 | 03:39 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
me too....i'm pretty sure Trickster knows its an exhaust cutout...but maybe he had a brain fart....
I'd say to just pop the shifter plate off your console, and if you look in, you'll see the shifter cable run through a black grommet. If you run it through there, it'll come out right above your trans on the driver's side and should be easy to route to your exhaust cutout.
Old Feb 28, 2004 | 08:12 AM
that sounds real good their, im glad i wasnt the only one that didnt get what he said. We all have brain farts sometimes
Yeah i was thinking of pullin the console so i can take a look at that stuff in their, thanks alot-
joe
Old Feb 28, 2004 | 08:31 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It was a rough night
Old Jul 22, 2004 | 05:08 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Just to correct, but there are at least six (6) of these plugs. 1 under each seat (totalling four) and one under each footwell.
The ones under footwell and driver/pass seat are the same size (large and kind of oblong) and the 2 under the rear seats are smaller.
I know this because I have removed mine to replace the carpet and glue, but cannot find replacements.
Old Jul 22, 2004 | 05:19 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you want to get technical about it, that would be nine of them. The four under the seats, four more for the front and rear foot wells, and one in the cargo well. There may be that many in your car, however there were only the ones I mentioned in mine. I quess it varied from year to year.
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
ericjon262
Sep 11, 2015 06:07 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
