How much should I expect to pay for a paint job
Old Feb 26, 2004 | 11:43 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I'm not looking for a bargan basement paint job. I want a good looking paint job. Here's what I got and what I plan to do. First off it's a 91' Camaro T-top with the famous peeling paint, I've been told that the car would have to be stripped to bare metal before it can be repainted does this sound right?? I plan on removing all plastic ground effects and anything that would get in the way of painting such as taillights, weatherstripping so on. I also plan on getting a new SS hood. I want to change the color from teal to black. I want everything painted, door jams, under T's. The only place I want left alone is the engine compartment, I'll leave that till I do a motor swap. How much should I expect to pay with everything I've mentioned??
Also when painting the door jams do they have to remove the doors or should I have them remove the doors?? And what about the rear hatch should they remove that??
Old Feb 27, 2004 | 12:59 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
to be done in a way that a 3rd gen should be will run 1500.00 and up.........
Old Feb 28, 2004 | 06:59 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
for that much work, even with all teh bullshti done by you, anywhere from 2 to 5 grand
Old Feb 28, 2004 | 07:43 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
3 grand for a good paint job, i wouldn't go any less d00d. Maybe you can beocme friends with a body shop owner likei did and get the work done for free and only have to pay the 1 grand for paint. But as cheap as you'll prolly find it $1500...
Shane
Old Feb 28, 2004 | 09:27 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Prices will be different depending on the place. Your best bet is to actually go to body shops around you and get an estimate. Check out other cars they're doing/have done and see how they've turned out. Do your research and you're less likely to be disappointed and/or ripped off.
Old Mar 1, 2004 | 07:26 PM
sleeperZ28's Avatar
Car: 86 z28
Transmission: built 700R4
im preping mine for paint right now and having it done by a dealership body shop painter that does lots of custom work at his house. he quoted me about $2500 maybe more. thats engine compartment and jams and gfx.
Old Mar 6, 2004 | 03:18 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Will they have to strip the paint all the way down to metal?? I have the peeling paint problem
Old Mar 6, 2004 | 03:19 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
peeling yeah, cracking yes
Shane
Old Mar 10, 2004 | 10:59 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
the paintjob on that is on my car is a $3800 job. it is the original paintcode arctic white w/ blue pearl.
oscarfromla
Southern California Area
Sep 1, 2015 12:39 PM
SlowAZ28
Members Camaros
Aug 31, 2015 07:53 PM
neekolzun
Aug 24, 2015 04:59 PM
kyle5647
Aug 7, 2015 03:08 PM
