People With Macewen Gauges..come in
Old Mar 2, 2004 | 11:35 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Does anyone have any pictures of their Macewen gauges in the day and at night? I'm very confused on what set to get for my 91 Z28.....The Macewens...or the Reverse Halo Gauge Set.....I need help....thanks
Old Mar 3, 2004 | 06:16 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
I know there are not 91-92 guages but they are Macewen faced gauges! This not my guages since my cars up for the winter i could not get any pictures but I have the same set-up!
Old Mar 3, 2004 | 06:22 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Those look awsome, is there anywhere with deals on those or do you have to order directly from macewen? And are those white led's behind those guages, they look very well lit.
Old Mar 3, 2004 | 11:04 PM
Engine: 5.7
I'm REALLY wanting a set...and I'll fork out the 92 bucks for them...but....I've emailed them twice...and I've PM several people on here about the 90-92 gauges....how they are backlit and stuff...but noone has responded...and that's what's stopping me. I think they look awesome in the day....but at night...I have still not seen a set of the 90-92 style gauge overlay's lit at night. They will not light up like the 85-89 style because they are made different....all of the numbers are accented in yellow...so if I put blue LED's in....it would look green. I was wanting to know if it is possible to take the factory gauge plastic out...that way...the yellow would be gone...and I could put any color of LED I wanted in. To tell you the truth...I wouldn't even care if they still had the yellow...but I want it to be even and bright..I don't want it to be "blotchy" and cheap....so I'm left with what kind of LED's to get...or bulbs....and noone has helped out so far.........also....is there anyway to change the color of my needle or do I need to get a set of needles off a 92? (92's are illuminated orange, 91's are yellow)
Old Mar 3, 2004 | 11:36 PM
Car: 92 Z28
..Im pretty much wondering all that other stuff myself, but if you remove the needle you can apparently remove the color by scraping the back with a razor and then either using a dry erase marker (to make it transparent) or paint to change the color
Old Mar 3, 2004 | 11:39 PM
Engine: 5.7
I thought about doing that too...just as long as the needles go back EXACLTY where they were before they were removed. You'd probably have to get transparent paint, very thing, to paint the back of the needles so they would still illuminate....anyhow..I JUST ordered those Gauge Overlays...I HAD to have'em.....now..just figuring out what to do about the back lighting....
How about these LEDS? WLED-W4 White LED bulb
12VDC White 4-LED Wedge Base Bulb (194/168 type)
Polarized
$ 2.59 (towards the bottom of the page)
here is the link: http://www.superbrightleds.com/cgi-b...=4571759.32668
Old Mar 4, 2004 | 01:19 AM
Car: 92 Z28
White led's would be cool, it would just illuminate alot more than the stock lights... I think the pic you posted has white leds now I just have to figure out what color leds to buy in order to get green? (that and find money to buy guages lol)
Old Mar 4, 2004 | 07:30 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
well, since no one else posted the 90-92 style pics....
Sorry, that is the best pic i could find of mine right now.
Old Mar 4, 2004 | 10:02 AM
Engine: 5.7
You don't happen to have any pictures taken at night do you? What kind of lighting are you running? Do you think the LED's that I posted would look good?? Here is a picture of how the white "4 in 1" LED would look.....is this to much? Would the gauges be blotchy if I got these?? http://www.eautoworks.com/html/ord-L...bs-1-22498.htm
Old Mar 4, 2004 | 10:25 AM
Dewey316's Avatar
Car: 1990 Camaro RS
no, i dont' have pictures at night, i am just using the stock lighting. so i have no way of knowing how the LEDs might look.
Old Mar 4, 2004 | 10:37 AM
Engine: 5.7
well how does the stock lighting look? Is it dingy? Is it blotchy? Just details would be great....if it looks good..then I won't even change my bulbs....
Old Mar 4, 2004 | 02:53 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
I've got the white gauge faces with red bulbs. Its not super bright, but its an even color, and I like the way it looks. I was going to try doing blue, but decided I didnt want to butcher my gauges trying to replace the yellow plastic.
Do a search, you will find alot of threads on this topic, including one with a guy who took some blue laminate and created his own face with blue numbers.
Old Mar 4, 2004 | 02:55 PM
Engine: 5.7
Is it true that you have to use a different bulb holder to change the 4 bulbs????? Is it very hard to change the bulb holder???
Old Mar 4, 2004 | 07:35 PM
Car: 92 Z28
If you get the right led's they should just stick right in. I believe he was talking about messing with the stock guages so there was no yellow.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
LC2 TECH
Oct 13, 2015 11:53 PM
MadOTC
Oct 13, 2015 04:46 PM
