stering column
Old Mar 8, 2004 | 08:48 PM
speedracer2000's Avatar
Want a title? Post!
Car: 1989,1979:rs camaros
Engine: 2.8,350
Transmission: 5speed,350 turbo
stering column
help how do you remove the stering column in a 1989 rs camaro
I cant find any way
Old Mar 9, 2004 | 12:46 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
there is 2 nuts or bolts (cant remember) just under the drivers side dash panel, then 3 i think on the firewall behind the carpet, then the steering joint, unplug wiring, and that should be it
Old Mar 9, 2004 | 01:02 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Lol I just swapped a steering column tonight.
There are 2 13MM nuts holding the column to the dash. Its actually a bracket with 2 studs on it welded to the firewall, its not part of the dash. They go up from underneat the column. Then, there are 3 10MM bolts which hold the column to the firewall. You will have to pull down the carpet and insulation a little to see these. There is one bolt which holds the column shaft to the steering box shaft in the engine bay. Look right behind the 'ragjoint' on the steering box shaft, and you will see it. This is easiest if you turn the steering wheel so that the bolt is horizontal. I'm pretty sure I used a 3/4" wrench on this, but I can't remember for sure. You will only need one wrench, the bolt has a square part under the head like a carriage bolt to keep it from turning. You will also need to unplug all the wires from the column. There is a big plug on the right side of it for the ignition, and a couple small ones on the left side. There's also a vacuum line to it, which goes to the cruise control off switch by the brake pedal. The ignition plug is kind of a pain to get off, but this might help. Its actually 2 plugs, take the black one off first. Theres a little clip think yo uhave to push in, and it should just slide off. Then, take the blue connector off. It has 2 more of the little clip things to push in. Tonight makes the 2nd time I have swapped steering columns in a thirdgen, I should be getting good at it by now :P
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Tweeks25
Sep 17, 2015 08:04 AM
383cam
Sep 9, 2015 06:01 AM
Ian Irvine
Sep 4, 2015 08:08 AM
