Can I Just Drill Holes and bolt on my gfx to my SC?
Old Apr 5, 2004 | 03:08 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
or do i need some sort of mounting bracket?
Old Apr 5, 2004 | 06:22 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you don't have the backing brackets on the GFX, then you will need to get those or try and fab some up.
Old Apr 5, 2004 | 07:36 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
sup bro, you will need the mounting brackets or fab some up like zepher said.
Mike
Old Apr 5, 2004 | 09:29 PM
Car: 1986 Camaro SC
oh, but do i need a bracket for the door piece too?
Old Apr 5, 2004 | 09:34 PM
Zepher's Avatar
Yes, but you may have that bracket already on the piece. If there are 5 studs sticking out on it, thenyou have the frame/backing plate.
Old Apr 5, 2004 | 10:12 PM
Car: 1986 Camaro SC
ok, so any car that came with factory gfx i could get the brackets off, thanks guys
Old Apr 5, 2004 | 10:35 PM
Zepher's Avatar
I can't answer that one.
Old Apr 6, 2004 | 06:13 PM
gilley's86's Avatar
Car: 1986 Camaro SC
Engine: 305, AKA 30WHY
I put ground effects on my 86. It was a sports coupe just like yours. I just welded on some thicker sheet metal for the gound effects on the door. Otherwise, the ones that attach to the doors and the ones below the quarter panel groundeffects, I just took some poster board, traced the design, and put wholes it. Lined it up on the body, a few quick wholes with the drill, and ta da. It was all done.
Gilley
83 Crossfire TA
Jan 3, 2016 01:26 PM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
