Removing TA steering wheel w/ airbag... search didnt help much
Subscribe
Apr 28, 2004 | 06:04 PM
i got an 89 TA and i want to take out the steering wheel and put it in my 87 Firebird... it dosent say it has an airbag but it looks like there is one.. first of all i cant figure out how to get the daM thin out and second i dont want to get punched in the face by an air bag if i do it wrong..
I did a search and they werent really that helpful to me
Can anyone help me?
here is a pic of the steering wheel, and in the next post is what it looks like under everything
thanks
tom
Removing TA steering wheel w/ airbag... search didnt help much-steeringwheel.jpg
Reply 0
Apr 28, 2004 | 06:07 PM
here is the rest of it..
PS. its possible to swap the key too right? i want that ignition because it has the security chip in it and the firebird dosent
Removing TA steering wheel w/ airbag... search didnt help much-collum.jpg
Reply 0
Apr 28, 2004 | 07:51 PM
That's not an airbag wheel.
You pry up that center piece from the side with a screwdriver or your fingernails if strong enough, and the normal steering wheel nut is underneath.
For the VATS you'd also need the ECM and compatible PROM.
Reply 0
Apr 28, 2004 | 08:21 PM
okay cool, what do the ECM and compatible PROM look like? i dunno steering stuff.. is it in the pic i got up there?
Reply 0
Apr 28, 2004 | 11:00 PM
I'm not sure on that one other than you need those 2. It gets asked a bit in DIY Prom, do a search on VATS and ECM in that forum and you may find it.
Reply 0
Apr 29, 2004 | 12:09 AM
He would also need the VATS control module, the harness for it and the starter enable relay and harness for it. The VATS control module is located beneath the defroster ducts on the left side of the instrument panel near the drivers right knee. The starter enable relay is under the left kick panel below the hood release cable.
Reply 0
Apr 29, 2004 | 08:08 PM
This is technically an opinion, but i think many would agree. Adding the VATS system would be way more trouble than it's worth. You'd be better off having a good alarm installed with a starter kill. To add VATS to you car you'd have to tear apart the entire dash and to make sure everything is compatible it could get very time consuming and expensive!
Reply 0
Apr 30, 2004 | 02:58 PM
Quote:
alright.. well im not gunna go through the trouble of taking out the VATS system then.. specially since i know not much about it... but
I took out the main bolt in the middle of the steering wheel and i still cant get the daM thing off! is there something else i have to do? or just pul really hard!.. when i try to screw off the steering wheel it just turns the collum along with it
Reply 0
Apr 30, 2004 | 03:27 PM
the wheels are put on very tight. If you go to an auto parts store you can rent or borrow a steering wheel puller to remove it. I think at autozone they hold $20 in cash and refund you fully when you return it.
Reply 0
Apr 30, 2004 | 03:47 PM
ahhh that expalins it... thanks
BTW im from round buffalo NY 2, go to ECC college
Reply 0
May 3, 2004 | 03:57 PM
Awesome, we should meet up sometime. Check out this thread https://www.thirdgen.org/techbb2/sho...5&pagenumber=3
A bunch of us from the Buffalo area have been communicating in there (it's up to 3 pages!) and some of us have already met up. We're looking to have a barbeque or something like that soon
Reply 0
Subscribe
