Pin On Cowl Hood
Old May 2, 2004 | 11:33 AM
1989GTA350's Avatar
Car: '89 GTA
Engine: 427 BBC
Transmission: TH-350
Pin On Cowl Hood
I'm looking for a pin on style fiberglass cowl hood for my GTA. The only one I have found so far is A 3" from Harwood for about $240. Are there any other companys that make these hoods in a larger cowl?
I don't need anything larger than a 6" cowl but need more than a 3".
I have looked into adding a glass cowl scoop to a stock steel hood, but between a steel firebird hood and the cowl scoop, Im already at about 200 bucks.
I really want a light weight fiberglass 6 cowl pin on hood for a third gen firebird but can't find one.
Old May 2, 2004 | 03:27 PM
1989GTA350's Avatar
Car: '89 GTA
Engine: 427 BBC
To answer my own question.
After a little more searching i found this, anybody had any experience with this particular hood and its fit??
http://www.hawksthirdgenparts.com/in...il?v=1&pid=394
Old May 2, 2004 | 04:06 PM
fast82-Z28's Avatar
Car: 1982 camaro Z28
Engine: 350, comp cams magnum 282h cam, edelbrock performer rpm intake, carter 625 cfm carb, msd hei upgrade kit, milodon gear drive, crane cams 1.6 rollers, more 2 come!!
Transmission: th350, 2600 stall, stage 3 shift kit
www.up22.com thats where i got my hood from
Old May 2, 2004 | 04:19 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Id just find a bolt on hood and drill it for pins if you can't find what you want in pin-on style.
Old May 2, 2004 | 07:32 PM
1989GTA350's Avatar
Car: '89 GTA
Engine: 427 BBC
Yeah I can do that, but usually the pin ons are alot cheaper, Thanks for the tip
Old May 2, 2004 | 09:55 PM
Air_Adam's Avatar
Originally posted by 1989GTA350
Usually the pin ons are alot cheaper
True, didn't really think of that...
Old May 3, 2004 | 03:57 AM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
what do you mean by pin on.
Does it mean that the hood doesn't open using the stock latches?
Old May 3, 2004 | 04:58 PM
1989GTA350's Avatar
Car: '89 GTA
Engine: 427 BBC
Yeah, basicly you have to use hood pins. Here is an example, My girlfriends 2" pin on cowl for her Nova
Old May 3, 2004 | 06:06 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
dont go to up22.com. They suck, i speak from experience. Not worth the money, go to harwood or someone else.
Old May 3, 2004 | 10:08 PM
1989GTA350's Avatar
Car: '89 GTA
Engine: 427 BBC
I also have heard bad things about UP22.com, What exactly did you have problems with?
The Hood on the yellow nova pictured is a Harwood. The fit was great and the quality is very high.
Old May 3, 2004 | 10:10 PM
1989GTA350's Avatar
Car: '89 GTA
Engine: 427 BBC
Ahh double post
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
loud91rs
Oct 5, 2015 10:05 PM
