Rear hatch strut problem.
Old May 16, 2004 | 10:19 AM
89IROCZTPI's Avatar
Car: 1989 IROCZ
Engine: Rebuilt 350 TPI
My passenger side strut mount? has sheared off from the body, shoving my hatch out of line. Is there any way to fix this? I unbolted the strut from the interior where the mount sheared off, and I dont see any way to attach screws or anything. Also, how can I compress the strut when I go to put it back on? Thanks!
Old May 16, 2004 | 11:38 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I will get back to you on how to fix the mount. In the meantime, there is no way that you will be able to compress that strut. You have to open the hatch and prop it fully open with something and then install the strut. If the hatch was opening when this happened, you are lucky it didn't do more damage. Pull the interior trim pieces in that area and take a look at it. Got a picture of it?
Old May 16, 2004 | 12:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is a picture of that area. Sorry, but it is the only one I have.
Old May 16, 2004 | 12:55 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
Ill take some pics and "try" to put em up(still dont know how). I was inside the car and the hatch was shut when I took the bolt out, the reason I did it from the back end is the screw is stripped out at the top of the hatch and it wont come out. So ill need to get a new strut then?
Old May 16, 2004 | 01:15 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
Ok, I ran took some pics and put them on my cardomain page, circled teh problem in red. Its the same problem on both sides of the mount, it basically has 2 ummm, id say rivits, but not quite, the portion that attaches the mount to the body goes right in between the body panels, so it doesnt interfere with the weatherstripping around the hatch. Anyways the pics can be seen on page 3. Thanks!
http://camaroz28.cardomain.com/id/89irocztpi
Old May 16, 2004 | 01:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If there was no damage to the mount other than that fastener breaking off, just re-install it with some new fasteners.
Old May 16, 2004 | 03:36 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
Thats the problem, theres no way to put in new fasteners, it looks like the mount was welded in some spots to the body and the upper portion that attaches to the hatch, the fasteners are part of the mount itself, and they are welded on it looks like. I was thinking maybe I could just drill some new holes, but it most likely interfere with the weatherstripping on the hatch.
Old May 16, 2004 | 04:33 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
need a better pick to see what your looking at, what is the other mount in the pic for? isn;t that where the strut goes. should be a verticle hole for the strut not a horizontal like your pic shows. are you sure that is where the strut was mounted.
Old May 16, 2004 | 04:44 PM
JeffW's Avatar
Engine: 305 tpi LB9
here is a pic of mine maybe this will help you describe what your looking for
should say cargo cover,......... is this where your strut was mounted? no wonder it broke very light tack welds not ment for strut mounting. mount you strut on the heavy bracket and you should be good to go.
Jeff
Old May 16, 2004 | 04:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I may be wrong in this Jeff, but what I think you are looking at in the left side of the picture is the strut mount where it has been pushed forward after breaking or where he placed it for reference.
Old May 16, 2004 | 04:58 PM
JeffW's Avatar
Engine: 305 tpi LB9
ahhhh ok now i see it. so let me take a look at mine and see what is holding it in place then.... be back.
ok mine is just tack welded two times on each tab that holds that bracket in. not sure how well a self tapping screw or two may hold that.
Old May 16, 2004 | 04:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
pic two
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
