About too attempt some body work....
Old May 18, 2004 | 08:22 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
those are my bad spots. both are solid and are not rotted thru. just bubbled paint and surface rust.
i am new to this so ima give it a shot as i like to turn my own wrenches.
i bought a cheap grinder to get the surface rust off. i got some rust remover for after i get it down. some filler to reshape it after.
and all the diff cleaning and prep products that are recomended for prepping the **** for paint. my question is.. anything i should look out for when i do this. other than bein very careful with the grinder? sandblasting etc is out of the question for me and id rather try this route first before welding in new metal seeing as its not rotted. if i **** it up i dont care. then ill go somewhere for some new sheet metal.
Old May 18, 2004 | 09:13 PM
3gc's Avatar
3gc
Car: Z28
Those shouldn't be that bad. I had similar rust except less severe. Just make sure you grind out all the rust and after you bondo be sure to seal it.
Old May 18, 2004 | 09:20 PM
Car: Corvette
Engine: 5.7
anything i can buy in a spray can from a store like a vht brand or something that will seal it good. as right now i dont wanna spend big bucks on good primer. atlrast not till i do the entire car.
i have a variety of primers one says it resists rust. will this work as a temporary fix(2 months or so)?
Old May 18, 2004 | 09:33 PM
3gc's Avatar
3gc
Car: Z28
I've always been told primer dosn't seal. In the fall of 2002 I painted a small part of my car that had some surface rust. Sanded it down, primered it and painted with touch up paint. When i sanded that area down this past december it didn't have rust under it. The paint looked horrible after a year of weather but it protected it.
Old May 18, 2004 | 09:38 PM
Car: Corvette
Engine: 5.7
i know you can get primer that does seal it well but its real $$$$
i want something cheap in a can that will work for ike a month or 2.
reason being as i painted my s10 front clip wit cheap primer 3 years ago and it doesnt have any rust yet. im sure it is on its way out tho
so i figure for 2 months it will be ok.
because when i redo it ima have a shop do it.
i jus wanna send it in without rust
Old May 18, 2004 | 09:51 PM
Car: Corvette
Engine: 5.7
i have this stuff at my work. so i get it real cheap. do you think it will work well for a couple months?
Old May 20, 2004 | 02:03 PM
Car: Corvette
Engine: 5.7
ttt
Old May 21, 2004 | 12:21 AM
jaredjames's Avatar
Car: 1982 Berlinetta
hey sin have u seen whats under ur ground effect yet?
Old May 21, 2004 | 10:05 AM
Car: Corvette
Engine: 5.7
nothing that cant be easily fixed
Old May 21, 2004 | 03:34 PM
jaredjames's Avatar
unless its a rustout right, check it out 1na these days. there might be a surprise.. there might not.
Old May 21, 2004 | 04:55 PM
Car: Corvette
Engine: 5.7
i have had them off there is nothing major. the metal is still solid enough it seems.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
LittleFranks
Oct 7, 2015 11:26 PM
Kenwood
Sep 4, 2015 05:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
