Found bar under air box? What is this thing? (picture)
Old Jun 12, 2004 | 08:03 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
While removing my air box to clean it up I found this thing just lying around in front of the hood latch.
What is it? Does it belong there?
Attached Thumbnails Found bar under air box? What is this thing? (picture)-thing2.jpg
Old Jun 12, 2004 | 08:49 PM
Charlie's87's Avatar
Car: '87 t-top, '88 'vert
looks like a hood support, to hold the hood up when it's open......................?
maybe the previous owner got tired of using a stick to prop up the hood and snagged that off some other car. was it bolted on?
Old Jun 12, 2004 | 08:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That's what it looks like to me, must have had some bad hood struts at one point.
Old Jun 12, 2004 | 09:15 PM
CaysE's Avatar
It's definitely a hood support. Definitely not an original part of your car.
Old Jun 13, 2004 | 08:06 AM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Not part of my car, good, because it was jay laying under the air box, probably making noise, =).
Old Jun 13, 2004 | 12:53 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
That looks very similar to the one I'm using on my Formula. It came on a parts car I got a few years ago, but I have no idea what it might have originally been installed on.
Old Jun 13, 2004 | 01:03 PM
CamaroRS385hp's Avatar
Car: 1987 Iroc-Z28
Transmission: auto
huh, so no thirdgens came with a hood support bar? my old 92 3.1 had a hood support bar, but it looked very stock. i never thought that it might not be
Old Jun 13, 2004 | 01:15 PM
FLYNLOW92rs's Avatar
It's amazing what people will do modifying their cars and refuse to replace the hood shocks...:lala:
The hood support bar is not stock....
Old Jun 14, 2004 | 03:25 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
seriously, F-- replacing those $50 hood struts. If you can get something like that off another vehicle nearby, and have access to a drill and two bolts- you've just saved yourself $50.
Old Jun 14, 2004 | 11:19 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
actually i can get those struts for about $13 a peice, not a bad price, but the hood propping stick that seems stock on all 3rd gens works fine for me.
Old Jun 14, 2004 | 11:39 AM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Just go get the struts. Hood struts aren't that expensive, and its VERY easy to replace them.
I don't see why people are soo adamant about not replacing them.
Old Jun 14, 2004 | 12:28 PM
At $28 bucks apiece up here, a pair is almost worth a tank of fuel. Gotta prioritize. :shrug:
Old Jun 14, 2004 | 01:24 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
because most people dont go under the hood often enough to rationalize spending 50-60 dollars to replace them.
Old Jun 14, 2004 | 02:07 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
plus that rod will never wear out like a new set of struts will
$24/each was the lowest I've seen
Old Jun 14, 2004 | 08:32 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Life time warranty at AZ or Advance. Cant beat that! THey last forever.
Old Jun 14, 2004 | 08:55 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Autozone... (in my area)
MIGHTY-LIFT
HATCH A95024 LLT $24.99
MIGHTY-LIFT
HOOD E95051 LLT $15.99
How often do the struts wear out exactly ? I know the OEM struts on my 91 were still working (barely but, still lift the hood slowly assisted)... that's what.. 13 years ? I paid $32 for another estimated 13 years service... doesn't sound that outrageous.
Old Jun 14, 2004 | 10:51 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
cmon people dont be so cheap, there not that expensive, i payed 18 each for mine, i must say its super cool not having to hold up your hood with a stick, once i put it on i couldnt stop opening and closing my hood, amazing how those things can hold so much weight, and plus they give you +5 hp
Old Jun 14, 2004 | 10:52 PM
CaysE's Avatar
I'd think most people here do. I got so sick of trying to prop up my hood everytime I wanted to check or change something, the $45 I spent was probably the best I've dropped on this car so far. Same with the hatch struts. Nothing beats convenient upgrades. It's like keeping the AC on your car. I'll be damned if I'm going to spend what I like doing most (driving) while sweating my ***** off.
Old Jun 14, 2004 | 10:54 PM
Car: 1990 firebird
Engine: 3.1 v6
one question can you tell if they are going bad, i dont want my struts to just slam down on me one day, thats the only thing im scared of, not like that hood weighs 10 lbs either,
Old Jun 15, 2004 | 01:10 AM
Hey, c'mon now! I like my 2 polished pieces of pipe! They fit one on either side on the outside of the seats. Looks like the forward bars of a 6 point cage at first glance! Left pipe fits the hood perfectly, right pipe fits the hatch perfectly! My wife instinctively knows which pipe to reach for, depending on which end of the car I'm heading to. Besides, if I got new struts, the kids wouldn't have anything to play with in the back seat, and nothing to bash me upside the head with while I'm driving down the road! And when I get my ride cherried out, I will have them chromed for shows! And discarding the worn out struts makes up for the added weight of the pipes, and makes access to stuff near the firewall easier.
:hail: custom hood supports!! :hail: :rockon:
Old Jun 16, 2004 | 07:08 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
if you go to advance auto, they are lifetime warrenty. it was nice to get $100+ worth of lift supports for free (front and back). it was also nice not to get whacked in the head anymore by the hood when it was cold.
Old Jun 16, 2004 | 07:12 AM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
you cant use steel hood shocks on a fiberglass hood thats why i have a prop rod off a ranger
Old Jun 16, 2004 | 10:20 PM
CaysE's Avatar
Custom struts.
Old Jun 17, 2004 | 04:07 AM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
yeah but bad hatch struts are extra security if you have a speakers in the hatch nothing like coming out in the morning and seeeing someone with thier head cut off lying on your pavement cause they tried taking speakers
Old Jun 17, 2004 | 04:25 PM
Car: 1990 firebird
Engine: 3.1 v6
hahaha thats so funny, it could be a lesson too, half the people that have broken into my cars are drunks, usually leave bottle caps and stuff so it wouldnt be unusual for a drunk guy to get his head banged by the hatch,
Old Jun 17, 2004 | 05:13 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: Found bar under air box? What is this thing? (picture)
Originally posted by wwnf
...What is it? ...
Official executive payment retrieval tool.
Old Jun 17, 2004 | 05:50 PM
CaysE's Avatar
They go bad gradually, unless they get punctured.
Old Jun 18, 2004 | 05:08 PM
25THRSS's Avatar
It's not a hood prop or anything like that. There are 2 of them that criss cross infront of the radiator in an X shape. I have no idea what they are for, but that's what it looks like to me.
Old Jun 18, 2004 | 05:14 PM
CaysE's Avatar
This is definitely a hood prop. Those radiator cross braces don't look like that.
Old Jun 18, 2004 | 05:15 PM
25THRSS's Avatar
looks the same to me
Old Jun 19, 2004 | 04:47 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
$25 a piece for me with a LIFETIME WARRANTY
Old Jun 19, 2004 | 08:17 AM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
It wasn't attached to anything so I took it out. Just like the dead mouse in the speaker hole. =)
Old Jun 24, 2004 | 12:32 AM
hellraiser319's Avatar
who needs the hood struts that cost alot or who wants to waste the time finding a prop rod out of another car? just look for the nearest pipe and violla u got urself a prop rod. found mine on side of road and been useful ever since
Old Jun 24, 2004 | 12:47 AM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
yeah my hood struts were worn down, so what did i do? Replace em? NAW, just bought a glass hood. Voila. And who said stock steel hood struts wouldnt work.
Old Jun 24, 2004 | 01:16 AM
Car: 1987 Iroc-Z28
Transmission: auto
hah, yeah i did the same thing on my old v-6. with the stock hood, i had to use the metal prop bar to hold the hood up, but when i switched to a glass BB hood my stock struts worked just fine
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Bob88GTA
Aug 18, 2015 03:31 PM
bryan623
Aug 10, 2015 11:33 AM
antares57
Aug 6, 2015 07:47 AM
