new auto meter gauge cluster pics
Old Jun 23, 2004 | 08:32 PM
BOTTLEDZ28's Avatar
Transmission: A4
here are some new pics of my 99% finished gauge cluster. I used all Auto Meter Ultra lites gauges. I retained the SES light, turn signals and high beam indicator.
pic may load a little big. I am trying to fix it if it does
Old Jun 23, 2004 | 08:38 PM
BOTTLEDZ28's Avatar
Transmission: A4
Old Jun 23, 2004 | 08:46 PM
BOTTLEDZ28's Avatar
Transmission: A4
another .
Old Jun 23, 2004 | 08:47 PM
turismo's Avatar
Car: 1989 Trans Am GTA
damn those actually look good. looks very professional.
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
Old Jun 23, 2004 | 08:57 PM
spearson's Avatar
Looks good other than that custom panel the gauges are sitting in. It just looks out of place, everything else on your car is tight though.
Old Jun 23, 2004 | 08:58 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Cool man. What are those mounted on, fiberglass, plastic, sheetmetal? How did you go about hooking everything up? Did you retain your stock wiring or did you go with custom wiring? Are those electric or mech. guages? What sizes are they? Sorry for all the questions, but I have really been wanting to do something similar with mine... I have black Pro Comps though!!
Old Jun 23, 2004 | 09:12 PM
BOTTLEDZ28's Avatar
Transmission: A4
the panel is a piece of 18 gauge metal. it is NOT the finshed product. I wil get around to a more finshed cleaned up pice over this winter. I cut those holes with a jig saw and did a lot of filing. I now have access to better machinery and will have a new piece made with a computer program. This will look a lot cleaner and I will end up having it sprayed semi gloss black at a local body shop. They owe me a few favors anyways. As for the gauges, the speedo and tach are 3 3/8. the rest are 2 1/16th. All gauges are electrical except for the vaccuum gauge. My oil pressure gauge is mounter in a custom gauge panel under my cowl. Pics of that will come this weekend. I used the orginal cluster frame that held all the bulbs and gauges. I just did a LOT of cutting and trimming to get these to fit in there. I reused the old cluster housing so that it would bolt right back in to the dash. I cut the plugs off the orginal harness, added a new connector and spliced the opposite end on the gauges. I found a harness connector from a 4th get Z in the bone yard. The harness connector has 10 wires in it so it helped it worked perfect. I used 2 of them. Now if I need too, I can just unbolt and un plug the whole cluster and remove it. I havent got the car running yet to see if its all set. my fingers are crossed though
Old Jun 23, 2004 | 11:12 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
I like your taste in gauges.
Old Jun 24, 2004 | 12:28 AM
spearson's Avatar
When all is said and done, it'll look awesome I am sure.
What color silver is that on your car?, I really like it.
Old Jun 24, 2004 | 03:32 PM
BOTTLEDZ28's Avatar
Transmission: A4
the color is Bright silver metallic or Sebring silver. Its the same silver used on 4th gen Fbodies.
Old Jun 24, 2004 | 04:11 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
nice. it looks like everyones goin with the ultra lites in the dash kinda look. im almost there i just gotto get speedo, tach and oil pressure and that it and everything will be backlighted with blue LED's. im goin to be using the Corvin classics cluster mount and wiring harness
Old Jun 24, 2004 | 04:14 PM
BOTTLEDZ28's Avatar
Transmission: A4
I originally had all Phantom gauges and it just didnt look right with silver paint so I sold them and got the Ultra lites instead. I am glad I made the change. I did the same with the 3 gauges I have under my cowl.
Old Jun 26, 2004 | 09:41 AM
ShadowZ28's Avatar
Car: 91 Camaro RS
Engine: L03 for now......
Transmission: 700R4 for now.......
let me know how all the wiring goes when you get it done. thats probably the next step in my buildup.... well after the 350 im grabbin this weekend
Old Jun 27, 2004 | 09:55 AM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Hey bottledZr28 for some reason I thought you had a forthgen dash in there?
Old Jun 27, 2004 | 05:46 PM
BOTTLEDZ28's Avatar
Transmission: A4
I use too but it didnt match ther new theme of the car. I wanted a more aggressive race look and the 4thg en dash setup just didnt do anything for me. I sold it it and used the money to buy all these new gauges and just put my stock setup back in.
Old Jun 28, 2004 | 12:19 PM
85maroz28's Avatar
OK ic atleast I am not crazy!
Old Jun 28, 2004 | 10:13 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Very nice and clean!
Old Jun 29, 2004 | 02:14 PM
BOTTLEDZ28's Avatar
Transmission: A4
How do you guy it would look if I used a piece of aluminum instead of that black steel? something like the finish on the NASCAR dashes.
Old Jun 29, 2004 | 03:37 PM
pardonme2711's Avatar
the way it is now looks awesome. but i think the aluminum would make it look even better. about how much did the whole setup of gauges cost u?
Old Jun 29, 2004 | 04:30 PM
BOTTLEDZ28's Avatar
Transmission: A4
no idea on the cost of gauges. just grag a sumit book and start adding the gauges up. The speedo alone was $200.
Old Jun 29, 2004 | 08:42 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
I used to have an aluminum dash insert in my old Monte Carlo. I gave it that swirled pattern that finished it nicely. Looked really hot with the black faced Auto Meters. I think an aluminum insert could look equally nice with your exsisting setup. Good luck...
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
