do i put these inside or outside?
Old Jun 27, 2004 | 07:02 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
on the 3 piece spoiler? do they go on the inside of the car or on the outside?
Old Jun 27, 2004 | 07:14 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I would think inside the car, but I'm not 100%
Old Jun 27, 2004 | 07:17 PM
Car: 1986 Camaro SC
yeah, it fits best on the inside
Old Jun 27, 2004 | 07:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
oops double post
Old Jun 27, 2004 | 07:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you will look at the car, you will notice three holes in each rear quarter panel at the back by the tail lights. The panel shown goes on the outside of the car with those studs going into the car through those holes.
Air_Adam's Avatar
I think he's talking about those washer-like objects
Old Jun 27, 2004 | 07:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
On mine they are on the outside and if you look at the picture I posted, that is where they appear to be. There should be some padding on the nuts that secure the panel. Mine did.
Old Jun 27, 2004 | 09:03 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Mine were on the outside also.
Old Jun 27, 2004 | 09:06 PM
Car: 1986 Camaro SC
when i put them on the outside it doens sit flush to the car
Old Jun 27, 2004 | 09:31 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
did you try to tighten it tight?
Old Jun 27, 2004 | 09:53 PM
Car: 1986 Camaro SC
not yet
i dotn have nuts or clips yet
Old Jun 27, 2004 | 10:08 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
umm isn't that dried up seam sealer? remove it all and put some new sealer in its place. it takes up the slack in the holes when everything is lined up. i think its seam sealer or is there some other type of putty? when i removed mine that is what ot loooked like since alot of it was oozzed into the car around the nuts that i had to remove to get a socket on the nuts.
Old Jun 27, 2004 | 11:33 PM
Car: 1986 Camaro SC
yeah its not smoth enough and it hits on the body, if i dont put them on the outside i will get water leaks wont i?
Old Jun 27, 2004 | 11:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That you will my friend, that you will!!
Old Jun 28, 2004 | 02:43 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
lol, it should be fine once you tighten everything down.
Jake_92RS
Jan 28, 2020 10:37 PM
g.l.mos
Aug 22, 2015 12:02 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
92camaroJoe
Aug 13, 2015 06:07 AM
