Ground Efects?
Old Jul 5, 2004 | 04:21 PM
Aredross's Avatar
Car: 1990 RS coupe
Engine: TBI 305.
Ground Efects?
Can anyone elaborate as to what trim and year models thes ground effects came on.
I would have done a search but I dont know what they are called so it kind of makes it impposible
Old Jul 5, 2004 | 04:32 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
The fender flare looks like a custom job, however the GFX on that ride were found on 91-92 Camaros.
Old Jul 5, 2004 | 10:59 PM
Aredross's Avatar
Car: 1990 RS coupe
Engine: TBI 305.
would those fit on my 90' cause I like that look a whole lot more than those flat ones I have.
Yeah I know the fenders are custom actuallly I was thinking about doing that with mine after I saw it.
Ahhhh the quest to have the most desireable car on the lot.
Old Jul 6, 2004 | 01:22 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
That looks like FLYNLOW's car. The fender vent is from a 81 Z28. The shape of the fender is stock. The GFX are 90-92
Old Jul 6, 2004 | 01:48 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
The vent hideously clashes with the front lines of the car and should've been mounted upside down to fit close to the wheel arch.
As said, all 91-92 camaros got those pieces...
EDIT: On second consideration it doesn't seem to match the lines of the car either way. The way it's mounted seems to be mismatched with the front of the car and if it were upside it would clash with the door/a-pillar.
Old Jul 6, 2004 | 05:10 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
EDIT: On second consideration it doesn't seem to match the lines of the car either way. The way it's mounted seems to be mismatched with the front of the car and if it were upside it would clash with the door/a-pillar. [/B][/QUOTE]
i would of went side to side with them that would change it to upside down and still be facing the right direction, that may work better.......
Old Jul 6, 2004 | 09:26 PM
Aredross's Avatar
Car: 1990 RS coupe
Engine: TBI 305.
Uhhh yeah like I asked would those Effects fit my 90
Old Jul 6, 2004 | 09:31 PM
JeffW's Avatar
Engine: 305 tpi LB9
umm yes like direct bolt on maybe drill a couple holes fro the front if i remember correctly. Try search now lots have been said about them.
Jeff
Old Jul 7, 2004 | 04:06 PM
Yes they will fit. You "may" have to redrill the mounting holes in your doors, as I've heard differentiating opinions on them. Other than that, they are a direct bolt in.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
Thaney9
Oct 15, 2015 06:37 AM
lewandom
Oct 1, 2015 08:15 AM
