Trying to get seatbelts out
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
But not happening.
I havnt tried the passenger side yet, but damn the drivers side. The bolt will not come loose at all. In fact my star socket it ruined now. Any ideas on how to loosen it?
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
Well, if you're not too woried about your carpet, you could spray some WD-40 or Liquid Wrench on it and let it soak in for a bit...
Car: 1992 Z28
Engine: 5.7 TPI
Thanks for the ideas.
Im not worried about the carpet. I am working to get it replaced actually.
And I did use an extension to get it out. That thing is in there TIGHT.
You could also use a long-throw ratchet and kick it, that's how I got a lot of stuck bolts/nuts off my car. A well placed heel can do wonders... just dont let it slip, that'll cause you to lose another torx head
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i used 1/2 drive sockets on my seat belt only way to move em. and that was after some $%*&^*&^%^ and a broken bit on the 3/8 ratchet.
so you did get em you say....
Jeff
Jeff
Engine: 305 tpi LB9
i bought craftsman set. was not going to buy another unless i lost it. 1/2 drive is the ticket. what size drive you using?
oh and something you may want to try is to get a bmf hammer and rap it a couple times not crazy but enough to shock it. sometime that helps if there is some rust hanging on it.
Yeah, I always buy craftsman, gotta love the lifetime guarantee
. I've stripped out a lot of sockets and bent a lot of screwdrivers working on cars...
. I've stripped out a lot of sockets and bent a lot of screwdrivers working on cars... Member
Car: 1993 Trans Am
Engine: 5.7 LT1
I did this today, its def. a T-50, I actually had to rap the torx head into the bolt with a hammer, but it went in pretty easily... it was in there TIGHT, but not tight enough to damage the bolt, I def. would say a T-47 would be too loose when dealing with something that is on there so F**king well.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Centerpunch right in the middle with a nice heavy mallet. Then PB Blaster or Kroil, let sit overnight, then centerpunch again right before you try. I've always used a t-50.
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
If for some reason you end up rounding that thing totally off on the inside, you're going to have to drill it out... and that could turn into a mighty fun undertaking.
Car: 1992 Z28
Engine: 5.7 TPI
No bother, i have had to do it several times but in other worse places (IE transmission pan bolts).
Car: 1993 Trans Am
Engine: 5.7 LT1
wtf bits do you use to drill them out anyways? i removed my rear seats and tried to get those fkn bolts out and ended up rounding them, so i tried drilling, got most of the way through and then it just stopped going any further, tried several bits, several sizes, bits for metal, bits for wood, i ended up just carpeting right over them. fn things. these problems i only had with the rear bolts... the fronts came out fairly easily with a t50.
Car: 1992 Z28
Engine: 5.7 TPI
WEll I drilled through it, inserted a bolt extractor (big) to get it out, and the extractor broke off into it. Then I tried freezing it and chizzling it out.
I have now come to the conclusion that discontinuing the camaro and closing the Van Nuyes plant was a great idea - therefore I know for a fact that the person(s) that installed my seatbelts at that assembly plant was laid off.
xbazzarex
Dec 1, 2015 05:25 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
