triangle window seals
Old Jul 20, 2004 | 09:59 AM
92HeritageZ28's Avatar
Car: 1992 Heritage Z28
Engine: 5.7l TPI
Transmission: A4
My car was broken into and the body shop that fixed it had to weld a new skin on the drivers side door. now the triangle in front of the window doesnt seal against the weather strip above it. is there any way to adjust this?
Old Jul 20, 2004 | 10:20 AM
88firebird's Avatar
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
Yeah, but its a little work... you'll have to take the inner door panel off first. That triangle seal is attached to a small length of window track. The whole seal/track assembly is bolted to a bracket. Now its been almost 2 years since I adjusted mine, so I can't remember exactly, but I think there are 2 bolts... loosen them, readjust the position of the seal, and retighten... that's how it was on my Firebird at least...
Old Jul 20, 2004 | 11:09 AM
Engine: 5.7l TPI
Transmission: A4
wow that sounds like a major pita.
Old Jul 20, 2004 | 12:24 PM
CaysE's Avatar
It's not all that bad if you've taken off the door panels before. Then again... everything's a pain until you figure it out.
Old Jul 20, 2004 | 12:27 PM
88firebird's Avatar
Transmission: 5 spd
Isn't everything a PITA when working on cars? ha ha
CaysE is right - if you've done it before, its not too bad... I've had to take the door panels apart on my car a few times... plus disasseble a parts car... I could do it on a Firebird in 1/2 hr now! First time I did it tho, took me a lot longer...
Old Jul 20, 2004 | 12:36 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Here's what you'll be looking at with the door panel off. The adjustments are made at bolts numbered 1,3, and 11.
Old Jul 20, 2004 | 01:50 PM
Engine: 5.7l TPI
Transmission: A4
Thanks Pete. That helps a bunch!
Old Jan 16, 2005 | 03:06 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
not hard to do, after panel is off and you have the two phillips head screws out that hold the foam seal stuff out of the way then theres the 10mm nuts to adjust the triangle assembly
good luck
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
blackandblue02
Sep 10, 2015 08:19 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Fronzizzle
Sep 8, 2015 12:10 PM
