5-sp shiftplate interchange
Old Jul 22, 2004 | 07:52 PM
BirdofFireBOB's Avatar
Car: 88formulatp1
Engine: 5.0
Transmission: 5
Will the 5-speed shiftplate from a '92 Camaro fit exact in an '88 Formula??
Old Jul 22, 2004 | 08:53 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
yes?
Old Jul 22, 2004 | 08:58 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
No the consoles are different
Old Jul 22, 2004 | 09:04 PM
nick418's Avatar
Engine: L98, Hemi 6.2
i belive they wont fit, the consoles were diff, diff interior set up then the Camaro
Old Jul 22, 2004 | 09:51 PM
StevenK's Avatar
Car: 91 Z28
that sux.
You could go with a 4th gen console w/ the manual plate for that
Old Jul 25, 2004 | 04:02 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
question, im doing a auto to manual swap, can i take the auto shift plate off and put a manual shift plate in without changing my center console? and are the 4th gen consoles a bolt in item or do you have to some modifacations to it to get it to work in a 88 firebird.
Old Jul 25, 2004 | 04:18 PM
colonboy14's Avatar
Car: Trans Am
Yes, you can put a manual shift plate directly in, but the problem is finding one. I did a manual swap 6 months ago, and still havn't found one. GM stopped making them, and there were very few made to begin with. If you find one, I get dibs on it cuz I did the swap first. It's really not that big of a deal not having one, I think I'm gonna try and modify my auto plate so that there isn't a gaping hole, even if it won't look perfect.
The 4th gen console swap is more involved, I believe, and I personally think it doesnt look good in our cars.
Don't let this discourage you from doing the swap, it's the best thing I've done for my car.
Old Jul 25, 2004 | 08:26 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
take measurements, make one out of sheet metal
Old Jul 25, 2004 | 10:49 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
making one out of sheet metal doesnt sound like a bad idea. but then i think it would clash with the interior. hey colonboy14 how long did it take you to do the swap? do you have any good tips?
Old Jul 25, 2004 | 10:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Nobody says you have to keep it natural metal. Paint it to match the interior, or maybe try some truck bed liner or something to texture it.
Old Jul 26, 2004 | 09:53 AM
colonboy14's Avatar
Car: Trans Am
Well, the install was pretty straightforward, the hardest part being hanging the clutch pedal. Make sure you cut out the carpet where the pedals bolt to the firewall, if you leave the carpet inbetween the firewall and the pedals, there won't be enough pedal travel and the clutch wont disengage.
All in all it took me 3 full days, but it was my first time doing anything of this magnitude, and I kept having to run out for parts, etc. One of those days was figuring out why my clutch wouldn't disengage.
Just do a search, theres a lot of info on this site, and pm me if you have any questions.
junkcltr
Aug 2, 2019 11:12 PM
Numbah-1
Sep 20, 2015 09:31 AM
sbrandon
Sep 9, 2015 07:31 AM
greenyone
Sep 2, 2015 03:39 PM
