Body work on my Formula
Old Jul 28, 2004 | 06:56 PM
Conman's Avatar
Car: 1987 Friebird Formula
Engine: 305 TPI (soon ot be 350TPI)((muwahahahhahaa)
Transmission: A broken 700R4
Here's my baby.
Status:
1. Driverside Qtr panel done, - primed
2. Decklid, old holes filled, new holes drilled, - primed
3. New wing, - primed
4. Window corner rust fixed, - primed
5. Roof dent fixed, - primed
6. Pass. side rust hole next up.
Overall shot:
Old Jul 28, 2004 | 06:58 PM
Conman's Avatar
The old wing - uh - crunchy is the word I'd go with.
Old Jul 28, 2004 | 07:02 PM
Conman's Avatar
The new wing - much lighter. So much so that when I was diassembling the decklid and removed the wing, my supposedly dead hatch struts macically lifted my hatch. Turns out that just the left one was dead. Go figure.
Old Jul 28, 2004 | 07:04 PM
Conman's Avatar
When I bought the car it had some bubbling at the top corners of the side windows - not any more.
Driver side;
Old Jul 28, 2004 | 07:05 PM
Conman's Avatar
And the pass side;
Old Jul 28, 2004 | 07:09 PM
Conman's Avatar
Not sure what caused the damage but it's gone now.
Roof;
Old Jul 28, 2004 | 07:13 PM
Conman's Avatar
Oh Sh*t. This will be fun.:lala: I guess that's why I saved it for last.
Old Jul 28, 2004 | 07:57 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
looks from the pics that your doing a good job. just take your time, it pays off in the end. im starting to get into body work more. im having fun with it also. good work :yourock:
Old Jul 28, 2004 | 08:03 PM
jbbiggs's Avatar
Car: 95 formula
Transmission: 4l60e
Looking good......
Block sand, Block sand, Block sand
Have fun
Old Jul 28, 2004 | 09:56 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
looking good, avoid the tape line primer on the roof. it may be hard to sand level and the paint may take diffrently. where that transition is.
Old Jul 29, 2004 | 02:46 PM
Conman's Avatar
Thanks, this is my first attempt at doing body work. Although the only reason that is sitting still this long is because my trans bought the farm at the end of July.
Old Jul 29, 2004 | 02:49 PM
Conman's Avatar
Does anyone know what that black adheasive is that seals between the hatch glass and the decklid?
My local NAPA said that is is a dealer only item!
Old Jul 29, 2004 | 02:54 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's basically ribbon sealer ( http://products3.3m.com/catalog/us/e...er/output_html ) like what used to be used on older cars front windscreens. Autozone carries it (not 3M though) in the isle with all the RTV stuff.
Old Jul 29, 2004 | 03:49 PM
Conman's Avatar
Sometimes the guys at my local NAPA are real sh*t weasles.
Old Jul 29, 2004 | 05:32 PM
JeffW's Avatar
Engine: 305 tpi LB9
ask for windshield tape at a parts store that is where i got mine, not foam core but it works just the same.
Old Jul 30, 2004 | 10:54 AM
Conman's Avatar
I'm going to start on that last rust hole in the pass. side quarter today.
Old Jul 30, 2004 | 02:27 PM
Conman's Avatar
In: 3rd Gens
Out: The previous Idiots that drove this car in the winter.
The progress so far.
Old Jul 30, 2004 | 02:30 PM
Conman's Avatar
Look at the top left hole. Can you guess what I used to make that hole? ...My middle finger! The cars under coating and seam sealant was holding it together.
Old Jul 30, 2004 | 05:49 PM
Conman's Avatar
IN; Die Grinder - thanks Dad!
OUT; Dremel
Old Jul 30, 2004 | 05:59 PM
Conman's Avatar
Most of the rust cut out.
Jorlain
Aug 24, 2022 05:11 PM
Terrell351
Jun 13, 2021 01:13 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
sailtexas186548
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
