Shot a quick test panel today
Old Jul 31, 2004 | 05:22 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
here is the color for my car, i decided to grab a old panel while i was primering to play with, i gave it a real quicky sand to give it some tooth. i did no even try to get anything straight or feather since it is just a test panel.
here is the primer on with 1/2 covered in my base coat oriental blue hok
Old Jul 31, 2004 | 05:24 PM
JeffW's Avatar
Engine: 305 tpi LB9
yes i am outside at this point the car is inside drying. here is some shots of the candy on they entire panel. and last one is with a quicky clear coat. remeber this is a test panel to see color don;t care that it fish eyed and orange peeled.
Old Jul 31, 2004 | 05:26 PM
JeffW's Avatar
Engine: 305 tpi LB9
here is the cleared panle 4 coats of candy and 3 coats of clear. all quicky layers i did let it flash. it may be easier to see without the plastic behind it now.
Old Jul 31, 2004 | 05:41 PM
camaro of solar's Avatar
nice color man i wanna see the whole car!
Old Jul 31, 2004 | 05:51 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
what exactly is candy paint?
Old Jul 31, 2004 | 05:55 PM
JeffW's Avatar
Engine: 305 tpi LB9
candy is in intercoat tinted clear coat. so for a base/clear paint job it ends up being base candy clear 3 stages. candy gives it a deeper look with color in it. look at candie91z's car his is candy red. there is another name for it but it is a red.
you can also see the diffrence in the first pic that blue is the base, at that point i could of cleared it to give it shine, i went on to candy and then clear you can see how much deeper it is.
i can;t wait to put it on the entire car. mine will be the left side the darker blue. depending on what your base it the color affect changes that is why i split the panel.
Old Jul 31, 2004 | 07:36 PM
Kandied91z's Avatar
your base is what determines the color...your number of tinted clear layers is what determines the overall shade and depth.
use heavy metallics to sparkle and shift colors. use flakes/pearls and otherwise to add prismatic depths. typically why gold and silver are used for base coats as they offer the most depth and shift of any colors you could choose.
looking good....
Old Jul 31, 2004 | 08:11 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Nice color choice man. I was going to use a blue very similar to that just slighlty darker but because my car was white and still in oiriginal paint when i did it I stuck with the white so I didn't have to do the engine compartment. That is one sweet color you have me drooling
Old Jul 31, 2004 | 08:21 PM
jay92,85,79's Avatar
Car: 85z28,
Looks good man. How so far did all your paint cost u.
Old Jul 31, 2004 | 08:24 PM
JeffW's Avatar
Engine: 305 tpi LB9
every thing including one extra gun for clearing 1300.00 the gun was only 140.00 devilbis good deal. that is epoxy primer, 2k, base , candy , and clear, and some cleaners wax n grease remover and gun cleaner (thinnner).
could of went with the hok kbc line which mimick candy but i figured what the hell. might as well do the entire thing.
Old Aug 1, 2004 | 12:49 AM
Kandied91z's Avatar
better choice....just practice a bit on some test pannels. you'll get it. also work with drying time between layers as that can affect it as well. if you want to be really tricky and had a extra gun around you could do pearl coats in between the coats of candy. makes an excellent effect.
Old Aug 1, 2004 | 09:38 AM
Spdfrk1990's Avatar
And watch out for the DIRT!
Old Aug 1, 2004 | 09:41 AM
JeffW's Avatar
Engine: 305 tpi LB9
how is the pearl shot is that just mixed in a clear? i was going to ask you about the blue pearl in your cars finish. I do have 2 guns and a touch up gun.
Spdfrk: test panel was done outside the car won't be done without proper booth set up.
Old Aug 1, 2004 | 10:17 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I believe Pearl is added on after the basecoat, or in your case you could do it inbetween the candy coats like Kandied said.
Old Aug 1, 2004 | 10:22 AM
JeffW's Avatar
Engine: 305 tpi LB9
hok has dry pearls i wonder how that would work if i mixed in with the candy in one gun and just candy in other gun... or put in every coat....... so many options so little knowledge
Old Aug 1, 2004 | 10:57 AM
Kandied91z's Avatar
you have to play with it...unfortunately there is no real rule book to painting. that's the fun of it too.
Old Aug 1, 2004 | 11:05 AM
JeffW's Avatar
Engine: 305 tpi LB9
would there be a better color choice for the pearls? say a red or green i would expect a blue would not give much of an effect as everything else is blue. i don;t want to get to purple either.
Old Aug 1, 2004 | 09:57 PM
There are many different colors of pearls. The red pearl over your blue would probably create a purple effect (trying to think back to my kindergarten days ). But a white pearl would probably look real nice, it creates a silvery effect... that is what I have on my car.
Old Aug 2, 2004 | 01:52 AM
Kandied91z's Avatar
white pearl or gold would be nice, small silver metal flake if your into that also...
Old Aug 2, 2004 | 10:00 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
the kind you can eat
Old Aug 2, 2004 | 11:04 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Its especially good on hot sunny days when its melting :drool:
Old Aug 2, 2004 | 11:09 PM
JeffW's Avatar
Engine: 305 tpi LB9
leave it to the canadians
lol
Old Aug 2, 2004 | 11:39 PM
Car: 1987 Z28
hahah funny freak lol...........sorry i got a sence of humor
lol lookin good
Old Aug 3, 2004 | 02:29 AM
Kandied91z's Avatar
have you tried taking out the metallic/pearl in the paint...or at least not going as strong. it adds more depth and shine without it. i'm seriously thinking of getting rid of the metallic as much as possible in my next color.
something more like this...
it's hard but you'll notice the shadowing effect with the crisp corners of the metal, this won't happen as much the more metallic/pearl you add.
Old Aug 3, 2004 | 06:44 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Here have a few more Better pic's of that car.
http://www.hotrodscustomstuff.com/WeissCamaro-01.html
Old Aug 3, 2004 | 05:15 PM
JeffW's Avatar
Engine: 305 tpi LB9
sweet color i like it, my metalic is already in the can comes that way. the panle i painted looks alot like that color i have to take it into the sun and see what it will look like.
jeff
Old Aug 3, 2004 | 09:01 PM
Car: 1987 Z28
is that santa driving the car? WHERES THE REINDEER!!!!! HUH!!?!?!
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
spaigo
Aug 21, 2015 07:46 PM
