91-92 Dash in an 84?
Car: 87 Monte Carlo SS
Transmission: 200 4R
I'm getting an 84 Z28 kinda thrown in for not a lot of money with this '87 IROC I'm getting . The 84 is a NICE car. Completely rust free. sat in a garage for years. Anyway, I know some people will get mad, but I dont care, my car. lol. I want to convert it to look like a 91-92. I know how to change over the GFX and bumpers and everything else, but will the dash swap right over? Guages and all. I'm converting the motor to TPI and I'll probably need to swap the dash wiring harness right? What all would I need to do? Any modifications? Thanks. I'll get pictures when I pick up the cars on friday. I sold my 91 for $900. The guy is picking it up and giving me the money on Friday, so thats when I get the IROC and the Z.
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I am doing the EXACT same thing right now. From the responces I got, the dash will fit, but the speedo is cable driven in the '84 and electronicly controlled in the '91.
I saw your conversion post. didnt notice anything about the dash though. How can this be changed? I'm swapping in a new engine and trans too. Hopefully 350TPI/T56 so, I'd be changing the wiring harnesses. Will the speedo thing be changed with the harness?
Car: 85 Z
Engine: 383
Here you go here is a link that will give you all the info you need for how to get things to work. I put the 91-92 cluster in my stock 85 dash but this year I went and put in the 91-92 dash so it would look better with the 91-92 cluster. Good Luck!
https://www.thirdgen.org/techbb2/sho...hreadid=186037
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
if you are swaping to a tpi motor and all.. as long as you put the dash harness in... and get a vss and speedo gears for the tranny (make sure it is an electric speedo vss) everything will work fine.. but if you are going to the t-56 you will need a dakota digital box or equivilant to make the speedo work... basicaly it is a straight forward swap if you get the motor w/ harness and dash w/ harness.... oh and if you are in need of a 91 dash (no harness though) i just happen to have one from doing a 4th gen dash swap.. any questions though let me know and i will try to help
Don
Don
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
if you are interested i have a perfect condition 91 dash sitting in my garage right now in the car still ..lol...that i am parting out give me a pm if you need it ill give you a price then
