Drilling Location.. HELP, I DON"T WANT TO DIE
Old Aug 6, 2004 | 06:02 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
where in the hatch area is it safe to drill? how deep can i go? i dont' want to puncture a hole in my gas tank!!! and explode or someoting... lol
Old Aug 6, 2004 | 06:31 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
umm... i doubt you'll explode your gas tank by drilling a whole in it. But, I think its like an inch under the floorboard hatch metal stuff in the trunk - if that makes any sense. Just drill where u wanna and after the first layer of metal it drilled, see how much farther or how much room you got.
Old Aug 6, 2004 | 06:45 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
what are you mounting?
I don't recommend drilling in the hatch area. I used velcro to hold my amps down, and it works really well.
Old Aug 7, 2004 | 12:38 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
If its for holding AMPs down over the tank do this.
Pull the carpet up and lay down a piece of MFD cut to size for the complete back top. Put carpet back down. Now your save to mount amps. if you ever deside to take em out. or sell the car you can remove the piece of mfd and have nothing to worry about.
Old Aug 7, 2004 | 01:09 PM
Dingley's Avatar
Engine: LG4 305
its actually for mounting the "BOSE for GM" speaker box in the back. it covers the well.. i got one and want to install it in my firebird. bad pic, but you can see it in this pic covering the well. anyways. i need to drill on the wall of the well towards the front of the car.
Attached Thumbnails Drilling Location.. HELP, I DON"T WANT TO DIE-camarohatch.jpg
Old Aug 7, 2004 | 01:20 PM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
If you're ever worried about drilling too far, then buy a set of these drill stops. They're pretty inexpensive considering the piece of mind they provide. Even if drilling through your tank doesn't cause an explosion, it's still a big PITA to fix!
http://www.jcwhitney.com/autoparts/P...atalogId-10101
Just place the collar around the drill bit and tighten the set screw at the desired depth for which you'd like to drill.
Old Aug 7, 2004 | 02:20 PM
Dingley's Avatar
Engine: LG4 305
okay... but how much room do i have so that i know how far i can drill.... inch deep? centimeter deep? what?
Old Aug 7, 2004 | 11:21 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The metal is like 18 gauge so you only have to drill 1/8" depth at best to poke a hole. The gas tank isn't right aganst that part of the well so you have about an inch or just slightly better to drill.
The po'man's drill stop.. vacuum hose...
Attached Thumbnails Drilling Location.. HELP, I DON"T WANT TO DIE-image1.gif
Old Aug 7, 2004 | 11:29 PM
lonniep01's Avatar
Car: 88" CAMARO
Engine: 305 TBI
drill stop
poor mans drill stop , just wrap bit with masking tape a little over 1/8 inch from bottom.wrap around bit several times
Old Aug 7, 2004 | 11:58 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
dont hit the lines
Fanatic1074
Oct 3, 2022 05:57 AM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
