squeaky seat w/big camshaft
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Anyone else have a passenger seat that makes noise at idle with a big cam? It just squeaks and squeaks as the engine lopes through it`s idle...anyone know where a shot of wd-40 would work best? I have plenty of stereo but rarely listen to it, but maybe I should start. I had a second gen camaro and it did the same thing, only difference was it ran on seven cyl`s
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
turning up the music always fixes the problem, my 81 toyota pickup shakes like a bitch at idle and loud music sorta helps. hah just my two cents
I would hit the seat tracks with WD-40 (or better) for starters. You might also hit the hinges where the seat folds forwards; spray lubricant in the hinge point and then fold the seat back and forth to work it in a bit. I don't have any experience with this issue, so hopefully someone will correct me if I'm wrong.
- 89_IROC
- 89_IROC
Car: 1983 Daytona Trans Am
Engine: LG4
Re: squeaky seat w/big camshaft
This is a first :lala: Well I guess I don't have to worry about that with my LG4
Car: '82 Z28
All kinds of things squeek and rattle in my car
Doesn't bother me much now a days, gotten used to it plus my exhaust covers a lot of it
Engine: LG4
I drive my '83 every day and rigth now the interior is fully gutted. I hear tons of sqeeks, rattles, and 1 million other noises lol.
Okay, looks like I`m pretty lucky to only have the one noise....I`ll try the lube on the hinge part but I`m thinking it`s coming from somewhere deeper in the seat than that.....also I`ll make sure to turn up the radio
As far as the exhaust it`s plenty loud...... enough to drowned out most of the regular creaks and squeaks (true dual three inch flowmasters with a big block huffin thru it) it`s just this one squeak, is loud enough to hear over all it. Off to the garage now
As far as the exhaust it`s plenty loud...... enough to drowned out most of the regular creaks and squeaks (true dual three inch flowmasters with a big block huffin thru it) it`s just this one squeak, is loud enough to hear over all it. Off to the garage now Joined: Dec 1999
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Did you ever solve this? My passenger seat sounds like a Parrot with the amount it squeaks!!
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
using JB80 chain lube in the seat tracks works much better than WD40.
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Lol your car lopes so hard the seat squeaks? I think thats pretty badass. Get some rubber to put under the rails of the seat maybe?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Car: 1986 Firebird Trans AM
Engine: LG4
I kinda like a few squeaks because it reminds me of the the cars that the character Stuntman Mike drove in the movie Death Proof (2007). :evilsmile:
Love those cars. :P
Love those cars. :P
