Firewall
Old Aug 20, 2004 | 07:06 PM
nianguaus's Avatar
Car: 1970 Javelin SST
Engine: 360
Transmission: 727
Firewall
I've been planning on buying the Classic Industries floorpans, but what do I need to do to fix part of the firewall?
Old Aug 20, 2004 | 09:51 PM
nianguaus's Avatar
Engine: 360
Transmission: 727
Bigger picture.
Old Aug 20, 2004 | 09:53 PM
aerosmithr0cker's Avatar
Car: 1991 Z28 clone & 1985 Fiero 2M4
Engine: 305 TPI (In Progress, Camaro) & 2.5L 4 cyl soon to be 3.4
Transmission: 700R4 (Camaro) & Isuzu 5 speed (Fiero)
find some sheet metal you can use as a patch and replace it. Or go to a junk yard and cut that out of a car. or you could always clean off the rust buy some por15 - expensive stuff, and coat it and it will never rust again but you will still have the pits from the rust.
Old Aug 20, 2004 | 09:54 PM
onebinky's Avatar
If it was my car, I would cut out all the rot and make a small patch panel yourself. Then just weld it up, paint it, and call it a day.
It looks like you only have one bend there, and it's not even compounded, so it should be pretty easy.
Old Aug 21, 2004 | 03:02 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
definitely cut out rust and patch in with new, welding and grinding is gonna be the only way
coat the hell out of it with body coating when finished, then paint
Old Aug 21, 2004 | 03:28 PM
nianguaus's Avatar
Engine: 360
Transmission: 727
Is this a normal problem for F-bodies?
Old Aug 21, 2004 | 05:06 PM
onebinky's Avatar
Not sure if it's normal, but I can tell you mine had it. Just fixed it a couple weeks ago.
Old Aug 21, 2004 | 06:27 PM
nianguaus's Avatar
Engine: 360
Transmission: 727
The drivers side is way worse. The inner rocker, part of the floorpan, and part of the firewall are rotten.
Old Aug 21, 2004 | 10:04 PM
onebinky's Avatar
That's weird how that works. My passenger side needed three decent size patches, but the driver's side was perfect.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
djmarch
May 8, 2016 11:32 AM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 21, 2015 10:28 PM
gta892000
Sep 16, 2015 12:40 AM
