My new SS Grill is in..take a look
Old Aug 27, 2004 | 10:35 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
here it is:
Engine: 5.7
another..
Old Aug 27, 2004 | 10:37 AM
Engine: 5.7
last one
I'll take the car out of the garage and snap a few pictures too...from a distance...
I bought the grill off of ebay for $25.00, it actually fits in an 98-02 Mustang....I had to hack this thing a TON in order to get it to fit right. I'm not working on putting an outter ring on it....
Old Aug 27, 2004 | 11:04 AM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
:hail:what is the coolest grill i have seen in a ss hood!
Old Aug 27, 2004 | 11:35 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
sweet:hail:
Old Aug 27, 2004 | 11:52 AM
Abubaca's Avatar
Love the car. Not so big on the billet insert look. It looks fine, but it's just not my thing.
...I think ChevyKen has one too, and I didn't like his either.
Still, you have one of the sweetest rides on TGO!!!!:hail:
Old Aug 27, 2004 | 02:20 PM
nick418's Avatar
Engine: L98, Hemi 6.2
84Custom you hav such a beautiful Z28. :hail: i love the new grill
Old Aug 27, 2004 | 02:28 PM
Engine: 5.7
thanks alot fella's
On my old grill, I used "expanded aluminum", it looks pretty cool, but it's was a very thin material...and it wasn't held in place very well....kind of cheap. With this billet grill, it's held in rock tight...also gives it a more custom look, and goes good with my wheels. I also put a "brushed aluminum effect" on the grill so it wouldn't look cheap and be bling-bling'n.
Old Aug 27, 2004 | 02:36 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
The grille looks good, but I'd paint the backing plate behind it a flat black so you don't notice that all the holes aren't evenly spaced. (most noticable in pic 1).
Old Aug 27, 2004 | 02:52 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
or cut the whole out....thats what I'm gonna do
Old Aug 27, 2004 | 03:52 PM
Engine: 5.7
It is black behind the grill , the flash of the camera caused it to lighten up a bit. You can't even see'em when you look at it.
If your going to install a grill like mine...you need the holes. I used wire to tie the grill through the holes. Without the holes..I'm not sure how you would mount it in the hood...maybe with an epoxy or something...but then..you couldn't take it out if you had to.
Old Aug 27, 2004 | 04:36 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Wow way to ugly up your car dude... jk it looks great! I just scored a Denali grill of ebay so it should prove to be an interesting project
Old Aug 27, 2004 | 05:26 PM
StevenK's Avatar
Car: 91 Z28
On mine, I plan to get some stainless mesh, like found on the front of ricers in front of the intercooler, and I'm going mount it using u shaped clips on the edges most likely.
Old Aug 27, 2004 | 06:32 PM
nolanr0413's Avatar
Car: Trans am
im mixed on them , they dont look bad and they dont look good. I could go either way on them . Its ok , i dont know if id do it but it deffy gives it a different look . I have to see it from a distance to be fully sure.
Old Aug 29, 2004 | 04:45 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Hey, that came out real good man!
How did you end up fastening it? Just making it a tight fit?
Good job!
Ken
Old Aug 29, 2004 | 11:11 AM
Engine: 5.7
Good job!
Ken
thanks man!
Well, what I did was use thin wire. Here is a graphic I came up with that explains out it is held in
The Wire wraps around a bar in the grill, and then the wire comes out of the back of the holes in the SS hood. I just twisted the wires and it will not move one bit.
Old Aug 29, 2004 | 11:50 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
I see! That's similar to what I was thinking too. The only difference is that in my hood there is one large oval opening instead of the four circular holes. So I was just gonna put two vertical bars on the inside of the large oval hole, directly behind the bars in the grille and tie them together like you did.
Ken
Old Aug 31, 2004 | 12:43 AM
Kandied91z's Avatar
something i'd need to see in person...right idea though and looks good.
Old Sep 1, 2004 | 09:52 AM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
Man I love that grill! Great work buddy!
Old Sep 1, 2004 | 08:13 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I like that. I like your whole car man. Looks good.
1990RSVERT
Exterior Parts Wanted
May 27, 2024 11:23 AM
CAMAROBEAV
European Region
Apr 29, 2021 04:54 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
