Hood Stuck
Old Sep 5, 2004 | 08:49 PM
dflahe's Avatar
Hood Stuck
Hi, All..The hood on my son's 91 RS is stuck shut...I clamped the release pull inside the car, climbed under, saw that the cable was moving ok..removed clamp, pushed release handle, back in, crawled under again, and the cable is 'at slack', in other words, the latch is pulled already to the point it should be released, yet it isn't .do these latches freeze alot?? we've been fighting this since he's owned it....I can see the bolt that holds the latch loop to the underside of the hood..i might be able to get a flex socket to get to it on the end of an extender bar...can any'yall tell me what size that bolt head is??? I'm ready to grab the sawzall.....if I get it open, it's hood pins from here!!!
Dana Flaherty
Pembroke, Ma
Old Sep 5, 2004 | 09:20 PM
traumatech's Avatar
Just had this happen to me on Saturday. The cable pulls a release, allowing the hold that grabs the hood to move. Have you tried pulling on the handle, holding it pulled as far as you can, and then have someone lift it? If that doesn't work, or if you don't have help (like me), I was able to remove the splash shield, which you've done if you can see the bolts. Figure out which part is moving when you pull the cable, then feel for the part holding the hood bar. You should be able to pull the cable and push on the hood part from under it at the same time. If it's so stuck it won't budge, I believe those bolts are 13 mm. When you get it off, take the latch off, clean it up good until everything moves freely, and lubricate well. That's what got me through this weekend. Good luck.
Old Sep 5, 2004 | 09:35 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Had a similar problem with my friends IROC-Z. Wouldn't open so tried we he drove the car around the block and the hood popped open. We tried prying it loose prior to this with no luck. Once the hood was opened, we adjusted the grommets by raising it higher.
Old Sep 5, 2004 | 10:03 PM
Red1992V6Rs's Avatar
Car: 1992 RS
Engine: 3.1
that happened to me too. my friend happened to lean in the hood and it opened right up. he put pressure on the hood right above the drivers side headlights
Old Sep 5, 2004 | 11:35 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Yeh, if you push down a bit and have someone pull the lever, it usually works.
When you get it open, use some brake cleaner to clean all the built-up gunk from the latch to enable everything to move freely.
Old Sep 6, 2004 | 02:19 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Try this, it worked for me:
- Pull handle so the hood latch is open
- Pull up on one corner of the hood
- While pulling, smack the hood sharply right above the latch
Never fails
Old Sep 11, 2004 | 03:10 PM
BigNg's Avatar
Car: 84, 86
Engine: 84 w/V-6, 86 w/305 V-8
Transmission: both auto
Just noticed something on my broken hood latch. The spring that is on there should be attached to TWO parts of the latch mechanism. I picked one up at a wrecker, and noticed that mine (broken) only has the spring attached to the part of the latch that holds the cable tight.
Old Sep 11, 2004 | 04:10 PM
Uni-Master's Avatar
Car: 89 Chevy Camaro IROC-Z Convertible
Engine: 350 Corvette Heads bored .30
Axle/Gears: 2.77
I just had this problem with my new vert. If you crawl under the front end you can reach up behind the mechanism. Then you can pull the little hook toward the left front which will release the hood. While your holding the little lever to the left have someone push down a little and then pull up and mine popped right free. The cable probably has too much slack and isn't pulling it far enough to open it.
Old Sep 11, 2004 | 10:47 PM
Belker's Avatar
My hood has never "popped open" since I've had the car. I pull the handle and hear a faint click. I then walk around front and push down on the hood and let up. It then "pops up" and can be opened normally.
Old Sep 12, 2004 | 02:38 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I've heard this one a few times, and it works quite often. After you pull the hood latch, and it doesn't pop, slam the drivers door, it might pop the hood. Might work, might not. From there adjust as many have said above.
Old Sep 12, 2004 | 02:44 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
sounds like my 88 gmc ...lol.....if i pop the hood i just walk around to the front and give it a little love tap over where the latch is and it pops right up every time ive been to lazy to adjust it i guess i need to do that today
Old Sep 12, 2004 | 03:08 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Then, after you get it released....
clean it!!, grease it, line it up properly... and you shouldn't have any more problems (well for a little while)
I've been pulling my drivers front fender off regularly recently, and just lifting the hood up to take the fender out, and i don't always bolt it back down properly, so the hood isn't lined up, so I pull the latch, push the latch, then go smack the hood, but when it's lined up it works fine.
But I spent a good time cleaning it, and then lubed it up.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
