4th Gen. Console
Old Sep 5, 2004 | 10:46 PM
90tagta's Avatar
Car: 1990 Trans Am GTA
Transmission: 5-Speed
4th Gen. Console
I see a lot of 3rd Gen cars with the 4th Gen console. Is installing a 3th Gen console in a 3rd Gen car very difficult or take very much work.
Old Sep 6, 2004 | 01:48 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I'm sort of confused. Are you asking how hard it is to install something that you already have installed? Or are you conteplating taking it out and putting in another one? Basically, what's wrong with the one you have now?
Either way, the hard part is maneuvering around the e-brake. 2 bolts held that down for me. There's a few bolts that hold the console in place...it's not hard.
Old Sep 6, 2004 | 08:16 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I think what he meant to say is, is it hard installing a 4th gen console in a 3rd gen car.
Old Sep 6, 2004 | 08:29 AM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
Installing it isn't hard, but making it look good in a Camaro can be a task. I've seen only a couple that look good. Tons that look OK.
As for a firebird, I've heard it's just bolt in and go.. but I haven't put one in a firebird so I don't know .
-Bud
Old Sep 6, 2004 | 01:06 PM
2Krazy's Avatar
Car: 1992 Firebird convertible
Engine: 3.1
If u are putting an automatic forth gen console in a 3rd Gen Firebird u have to slide the shifter towards the drivers seat atleast 2 inches, i am in the process right now, just trying to figure out where to mount my power window switches.
Old Sep 6, 2004 | 01:08 PM
90tagta's Avatar
Ya, sorry about the confusin. Typing error. And my TA's a 5-speed not an atomatic.
Old Sep 6, 2004 | 02:16 PM
MNformula350's Avatar
It'll bolt right into your car like it was meant to be there,just bolt it in with the two bolts in the glove box in the center and your done. here's a pic of it in my 90 Formula.
Old Sep 7, 2004 | 11:52 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
this is one of the easiest mods, especially since you have a manual,
here is what my setup looked like awhile back,
Old Sep 7, 2004 | 02:07 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
takes a little custom fabbing for the for the automatic. move the shifter back, and some dremeling. manual is bolt on. for a camaro, you need the firebird HVAC and radio console.
Old Sep 9, 2004 | 10:16 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
mine was a PITA, cause im soo picky. i think it fits better than any ive seen, and i made a trick bracket to hide the hole in the top out of some plastic. if i could find the pics, id show you.
all in all its not hard, just depends on how custom you wanna get, or just bolt it in and have it look like crap. i used poly fill from an old pillow around my floorpan to build it out to match the console. id say it looks pretty factory after some tweaking.
dont bleed on the carpet. and keep band-aids handy.
j/k
Old Feb 9, 2006 | 04:32 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
dingly. do you have pictures of what you did to your tranny tunnel to get your shifter ti line up? did you ahve to hammer down the tunnel at all? thanks
Old Feb 9, 2006 | 06:25 PM
JB22's Avatar
Good info here
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Lbibb
May 5, 2016 12:00 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Dragonsys
Sep 25, 2015 03:51 PM
Nikole
Sep 24, 2015 08:12 PM
