paint prep?
Old Nov 21, 2004 | 02:38 AM
ssnova69's Avatar
Car: 1987 camaro z28
Engine: 305 tpi
paint prep?
How should i go about preping the plastic bumper covers for paint? Should i sand them, use stripper or what?
Old Nov 21, 2004 | 03:09 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
sand em. striper will destroy the urathane, use high grit papers like 220 320 no 80 grits it will also ruin the bumper cover.
jeff
Old Nov 21, 2004 | 07:31 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Stripper is OK for urethane, as a matter of fact, they even make "urethane safe" stippers. But a heads up, it WILL appear distorted which is probably what Jeff was refering to. But once you clean it off and let it fully dry, the cover will go back to shape in about 24-36 hrs.
Old Nov 21, 2004 | 07:39 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Also don't forget that if you take it down to bare plastic, there is an additional step before the primer.
Old Nov 21, 2004 | 01:16 PM
JeffW's Avatar
Engine: 305 tpi LB9
adhesion promoter and flex additive if off the car.
Old Nov 21, 2004 | 01:41 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Jeff, any problems with flex additive? Older versions had a tendancy to fade faster. I haven't used any as a result. I have found that most modern paints are very flexible out of the can.
Old Nov 21, 2004 | 01:45 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Same here. My friend has had great results for over 2 years now, and my cars been find for 6 months.
Old Nov 21, 2004 | 05:46 PM
ssnova69's Avatar
Engine: 305 tpi
well thanks guys. it is off the car the cover is brand new. and the back one still has the stock paint on it but its still on the car. what are the main things i should worry about besides sanding and painting?
Old Jan 18, 2005 | 11:37 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Just thought I'd ask how it went. My nose needs to be repainted now, because between a parking mishap and the crappy single layer of paint with no flex agent that the last owner used, the stuff comes off on your fingernail...
Old Jan 19, 2005 | 02:03 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
Ditto.. my car's going in to see Earl Scheib in a little while, and I want to do all of the prep work correctly. What/where do I get a flex agent? Should all of the polyurethane be sanded down? What needs to be done to get the paint job to last for a while and still look good?
Drone358
Sep 21, 2015 08:54 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
TheExaminer
Sep 6, 2015 11:40 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
