BIG problem, please help.
Old Dec 3, 2004 | 12:45 AM
87 L98 TA's Avatar
Car: 1987 Trans Am
So I'm blah blah **** wankin around to try and find my rpo sticker and something posessed me to pull the sub box out of the hatch, and whammo about 10 gallons of freakin fish tank.
I don't think my buddy knew about this either when he sold it. I think he would have told me...
I just pulled the spoiler and sealed the holes with duct tape till they can be welded.
leaky stock spoiler sealant let it in?
from what I can see all the weather stripping is good. If I had to guess I think its coming in from the taillight area? It's dark now and I'm trying to get it all out, but is this a typical bird problem?
ANYYYYY help will be appreciated!!!!
Old Dec 3, 2004 | 12:54 AM
Cyfun's Avatar
Car: '83 Trans Am, Black on Red
Engine: LG4 305ci V8 w/ CCC-Qjet
Transmission: Rebuilt 700r4
Axle/Gears: 4th gen 2.37 posi w/disc brakes
Just curious, but did you notice the car handling funny before you discovered this?
Old Dec 3, 2004 | 01:13 AM
bottledbird68's Avatar
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
Take a look at the rear corners of the hatch weatherstrip and see if they're crushed flat. I've seen this happen on a couple of friends cars. New weatherstrip solved it right away.
Old Dec 3, 2004 | 01:18 AM
ll-84camaro-ll's Avatar
Car: 91 Z28
Transmission: 4l60e
yup. thats probly your problem i had the same thing in my 84 camaro the weatherstiping was crushed flat and if we got a hard rain i would actually have to use a cup to get the water out of my trunk but new weatherstriping and it fixed it.
Old Dec 3, 2004 | 07:38 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Yup, flat weather striping at the corners of the hatch.
Old Dec 3, 2004 | 07:56 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
ALSO check under your carpet... one of my cars had this happen and the carpet was dry, but when I lifted the carpet therewas 2 inches of water... I vacuumed it out and then put a fan on it until it was gone... When I got the car the hatch did not close right because the pull down actuator was busted by slamming.
I thought there was a drain hole in the bottom of that area under the compartment so this would not happen tho...
John
Old Dec 3, 2004 | 08:35 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
no actual drain hole... but there's a hole that was part of factory that they put a metal piece on and slap a seal on top of... it's kinda big though...
Old Dec 3, 2004 | 11:57 AM
87 L98 TA's Avatar
Car: 1987 Trans Am
I don't know when it got in there, but I didn't notice...
The "tub" in the hatch was 90% full almost up to where the spare compartment is. A couple days ago when I took out a curb I had checked under the body to see if I had ripped anything off and there was a little bit of water SLOWLY moving down the tank, I thought nothing of it naturally.
Off topic, but I'd still like to find my rpo sticker. its not in the console or in the locking compartment? I'm assuming its long gone.
Old Dec 3, 2004 | 11:59 AM
87 L98 TA's Avatar
Car: 1987 Trans Am
shot of the stripping
Old Dec 3, 2004 | 12:35 PM
okfoz's Avatar
Sometimes the rear defog wire that attaches to the window gets twisted in a way that it gets closed in the weatherstrip, I try to keep mine twisted so it does not happen.
John
Old Dec 3, 2004 | 12:45 PM
87 L98 TA's Avatar
Car: 1987 Trans Am
I actully just noticed today theres no wire hooking up the defrost, so that can't be it... lol.
Car has been a real disappointment recently. The previous owner was convinced it had posi and I just jacked it up and it doesn't, unless I'm a moron.
Old Dec 3, 2004 | 01:15 PM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
In the pic. of the weather stripping, you can actually see where the water ran down across your plastic trim.
I just check mine every time it rains. I did replace the w/stripping, so it only leaks about 1/2 the time now. I just check it after every rain storm now.
Old Dec 3, 2004 | 01:23 PM
87 L98 TA's Avatar
Car: 1987 Trans Am
I can see what you're saying. Half the time is still way too much. Could the lack of weight on the hatch cause sealing issues from pulling the spoiler??
Old Dec 3, 2004 | 01:30 PM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
If it has the power pulldown system, then I'd think the answer would be no.
Why don't you try pulling the rear access panel off and having a look at the motor system. If it's misaligned, it could be not pulling the hatch down far enough, which in turn would let water in.
Old Dec 3, 2004 | 03:36 PM
okfoz's Avatar
Actually with water back there you should get better Front to rear balance
John
Old Dec 3, 2004 | 04:18 PM
Cyfun's Avatar
John
Lol yeah. If anything, you'd want it full of water rather than just half full, cause at half full you'd have shifting weight.
Old Dec 3, 2004 | 08:44 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
throw some live goldfish in there and call it the fish mod youll be the only one with that
Old Dec 4, 2004 | 01:51 AM
87 L98 TA's Avatar
Car: 1987 Trans Am
I checked out the water spot in that pic, and I think it only looks that way in the picture. I didn't see any spot where it was, though I think that spot is the culprit.
thanks again
Old Dec 4, 2004 | 07:05 PM
CaysE's Avatar
The weatherstipping is not the problem, most likely. I have the same leak, replaced the hatch weatherstrip, and still had the same leak. The problem is on the underside of the decklid. You will see a plastic square that fits the indentation on your weatherstripping on both sides. There is a gap between two body panels behind this plastic piece. Get some black weatherstrip adhesive and fill it up in there from the INSIDE only (meaning the side that faces toward the interior of the car). This should keep water out of the hatch well.
The problem isn't completely fixed at this point, it is just draining the water to the outside of the weatherstripping instead of into your car. The real leak is the decklid-to-glass seal. You have to take the decklid off, clean up whatever rust you come across (you'll probably find some), and re-seal it to the glass properly.
Old Dec 5, 2004 | 03:01 AM
87 L98 TA's Avatar
Car: 1987 Trans Am
There isn't any rust on the decklid. I think I DO know what squares you're talking about, and if so one of them was duct taped on.... lol.
My buddy who owned it before me said he never had the problem though, so maybe when I pulled the spoiler it gave it the little gap it was waiting for to start the leak...
Is there any way to adjust the pulldown motor?
Old Dec 6, 2004 | 03:32 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
When I swapped decklids (new spoiler), I had a leak here and had to go back and do some extra sealing... the new decklids old sealant did not all come off. I had to really watch to be sure the butyl tape sat level the second time. Any low spots for some silicone glue. The final test was getting in the hatch while Joe shot water on the deck from different angles to be sure it sealed. It was not a rust problem for me, just the new sealant not filling in properly.
But if you buddy is sure he did not ahve a leak...
I would say its the removal of the spoiler. Sealing with duct tape is not going to keep the water out completely. Joe did that on his and the tape adhesive kept letting loose. The sun rotted the duct tape and it deteriorated. See the heat of the sun will loosen the adhesive.
If I were you and was not going to weld the holes in the next week or 2...I would go to Autozone and get some of the big black push pins from the help section. They have the little plastic fingers that look like brissel brushes. Get some 3m double sided tape and place that all the way around the bottom of the pin. Then stick that to the car and push the pin in the spoiler hole. The tape will keep the plastic pins in the hole. Then cover that with duct tape. Will last longer. The double sided tape will work as a back up seal to the duct tape. The double sided tape should keep the push pin up high enough that you can get a razor in there later to scrape the tape loose. Then you can get a door panel tool under the edges and pull the push pin back out of the holes when you are read to weld the holes...
Old Dec 6, 2004 | 01:39 PM
87 L98 TA's Avatar
Car: 1987 Trans Am
I KNOW water isn't coming in from the spoiler holes. It probably will eventually, but its sealed very well for now. I think it is coming from the drivers side of the decklid because of not sealing tight against the stripping. How to fix it, I'm not sure....
Old Dec 6, 2004 | 04:37 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Easy way to find out where the leak is coming from...fold down the back seats, lay in the car while someone spray's the back end of the car with a hose..see where the water comes in.
Old Dec 7, 2004 | 02:32 AM
87 L98 TA's Avatar
Car: 1987 Trans Am
lol brilliant, wish I'd thought of that. Should work unless the leak is so slow it took weeks to fill up...
Thanks!
Old Dec 7, 2004 | 05:39 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
now this guy is a tech of some sort, thats what I was about to say... try to recreate the problem to find the source. With that much rain water, it will be pretty evident.
Old Dec 7, 2004 | 11:18 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
I've learned a few things in my age ...good way to buy a car to look for leaks, ...the guys in the bowling green plant use the same process in a more "advanced" way to find leaks in new vettes if they exist...also..if you dont' see where it comes in, you may need to pull off a few interior panels to see behind them...it's not too hard..i can trip 2/3 of my back end in like 5 min w/just a screwdriver
Old Dec 9, 2004 | 02:07 AM
redraif's Avatar
I said that in my own way....you guys got to pay better attention!
Old Dec 13, 2004 | 01:12 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
What's the deal? did you get it fixed? just wondering whats going on and how its going.
Old Dec 14, 2004 | 04:06 AM
87 L98 TA's Avatar
Car: 1987 Trans Am
I threw a hose up there and it runs it plain as day through the crushed rear corners. Being that its winter, covered, and not being driven I'm not in much of a hurry, but HOPEFULLY new stripping will do the trick, maybe adjusting the motor down a little to compensate for the spoiler weight loss....
Frismund Snoid
Aug 27, 2015 11:08 AM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
overdriv
Aug 20, 2015 03:52 PM
