Outer Window Sweeps
Old Dec 4, 2004 | 03:46 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Outer Window Sweeps
I just bought a pair of these outer sweeps and have a question on how to install them. The orginal sweeps have a plastic rivet which will break off when removing the old sweeps. What is the correct method to install replacement outer door sweeps?
here is a picture of the door trim and sweep felt that will have to be removed and replace.
Old Dec 5, 2004 | 08:08 AM
_max_'s Avatar
I used 1/8" aluminum rivets on mine
Old Dec 5, 2004 | 08:27 AM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
dude the holes for mine didnt even line up i had to drill the holes farther down i was so pissed.. and like it got alittle bend in it ..i hate them sweep things
Old Dec 5, 2004 | 08:57 AM
DTL504's Avatar
Where did you buy them window sweeps from? I bought mine from A1 Auto.
I will check later and see if I wil have any problems.
Old Dec 5, 2004 | 09:17 AM
Car: 2002 SS
Engine: Ls1
im not sure i'll have to ask my dad.. im sure if i find out that he bought the wrong ones by accident that i'll buy new ones later on when i get to it.. just cause im **** and everything has to be perfect lol : ) i'll find out later tho
Old Dec 5, 2004 | 09:27 AM
DTL504's Avatar
Thanks please keep me informed? I dont want that to happen.
Old Dec 5, 2004 | 11:23 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i drilled holes and used really tiny black zip ties.
worked like a champ.
Old Dec 5, 2004 | 11:32 AM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
i just installed mine from A1 auto too and had to redrill a few holes.I use flat screws like the ones that hold the t-top weather stripping frame on.Looks great
Old Dec 5, 2004 | 01:15 PM
Car: 2002 SS
Engine: Ls1
lol same here forum.. and plus why need to put 20 screws back in ? that was retarded i put like what 3 back in lol
Old Dec 6, 2004 | 03:15 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
If they are new sweeps and made for the car...I think what gm did is melt the plastic insert pieces so they would widen and hold the sweep to the plastic window sill. If I remember what mine looked like... If that is truely the case you could heat up a flat metal object with a torch and press the plastic shafts that go thru the holes down to hold the sweep
The drill and zip tie method is a simple good idea. I should have thought of that. We tried to use metal rivets and it was a pian. they would not squish flat enough!
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
