Carpet color change..yes or no?
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
My carpet is in good shape..no rips or tears or anything. But..in certain lighting..and in pictures...it has a brownish...gross look to it. I recently change all of the interior plastic to Ebony..which matched the seats really well. I spraed the kickpanel carpet area with the ebony spray...and it looks really good...very dark..and matches well. Should I spray the rest of the carpet? Here is a picture of the kickpanel area:
If it wasn't for the roll bar and the console...I would get new carpet in a heartbeat...but..the roll bar was VERY hard to install...and I have so many electronics running through the console...I wouldn't wanna start all of that completely over. (Volt Meter, McCord PP, Bass Boost, Fan Switch)
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
is the cage welded in? if it is it shouldnt be all that hard should it just lay it in a trim? and the center console that kinda sucks but if u dont like the color in some pics then i would say screw it and change it .... either that or have it dyed..... dont konw how much it would cost but...... i am gonna change my interior from gray to the ebony when i do my 4th gen dash swap.... so it will match and then get black carpet... or ebony.... dont know yet.... but all i can say is great car and good luck
Engine: 5.7
the roll bar is a bolt in...but I tell ya...it was such a TIGHT fit. I thought I was going to cave the top of the car or something because it was such a tight fit. And if I decided to take it out..I would probably do more harm then good...
Car: 88 Trans Am
then i would think about having it dyed.... like i said i dont know how much it would cost but that might be your only option.....unless u could just edit the pics and just not think about it.... but if u are like me then it would bother me till no end lol....
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Yep...Thats what i did, I had the black on grey leather. Changed the interior over to all black with Graphite leather seats. I love it!
Even new The Grey carpet always looked like you described kinda dirty.
Engine: L98, Hemi 6.2
Originally posted by Kandied91z
then he would have to do the center console and doors to match...
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Just checked out JCWhitney. They had "ACS" Carpeting for $160. It didn't specify if that was for the front, rear, or both pieces. I'm not sure what to think about that right now, and I'll be needing new carpeting this spring
Car: 88 Trans Am
hey so what color are u gonna go with with your 4th gen dash?
Car: 91 RS
Engine: 355
if you can just spray it like you did the kick panel then just do that, cuz I think that kick panel looks really good like that.
Car: 91 camaro z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 410
you might as well go all out and get new carpet if its in the budget. Did you have your cage custom made or did u order it from somewhere?
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
Dragonsys
Sep 25, 2015 03:51 PM
