wth? How'd that hole get there?
Old Dec 8, 2004 | 07:36 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Ok, I was a little dismayed to see this shortly after I bought the car. Never seen anything like it, and I have no idea how I might go about fixing it.. ideas?
Old Dec 8, 2004 | 07:39 PM
305q_ta86's Avatar
Transmission: 5 spd
Old Dec 8, 2004 | 08:04 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
looks like a rust hole.
could have hit something in the road,and it shot up threw the metal.
no telling.
Old Dec 8, 2004 | 08:07 PM
305q_ta86's Avatar
Transmission: 5 spd
Yep that's what I figured. The rest of the car has new paint, and there is some evidence of rust in other places, but it's not nearly anything like this.. I dont think it's a big deal, so I will probably just leave it..
Old Dec 8, 2004 | 08:21 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Almost everything with rust starts out as no big deal... next thing you know your replacing metal around the strut towers.
I would nip it in the butt while it's still a small spot. It would be easier to fix it up now than waiting acouple years.
---EDIT---
Here's a quick post I grabbed on rust removal. https://www.thirdgen.org/techbb2/sho...hreadid=187405
Lots of others you can find using the search.
Old Dec 8, 2004 | 08:28 PM
305q_ta86's Avatar
Transmission: 5 spd
Any suggestions how?
I was thinking just grind and weld sheetmetal..
Old Dec 8, 2004 | 08:31 PM
Engine: 383 SBC
Here's another https://www.thirdgen.org/techbb2/sho...hreadid=134528
Basically though I say fix it before it spreads, unless you don't plan on having the car that long.
Old Dec 9, 2004 | 10:22 PM
crazyn8's Avatar
Car: 55 Chevy (the only one that counts), 80 TA, 85 TA, 87 FB
Engine: BBC, BBC, SBC, none
Transmission: M-22, TH400, TH350, none
That rust is from water comming in through your hood vent next to the fender (they rust out faster on driver side-- especially if someone dripped some brake fluid there first). But do get it fixed, it will spred fast if you dont. Make sure to get all the rusted metal cut out and weld in new.
Old Dec 10, 2004 | 11:51 PM
305q_ta86's Avatar
Transmission: 5 spd
Yeah okay thanks for the help. I will try to take care of it this spring...
Old Dec 17, 2004 | 03:35 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I saw rust in the same spot on my parts car and it started on my 84 TA also, got it taken care of when the engine compartment was repainted. I'll bet that the rust continues all the way down into the tight corner under the bulkhead. in fact, in the picture you can see leaves, dirt and other stuff that's settled into the corner. Dirt + water in a tight space = rust. Definitely clean it out well and see what's going on down there. Try to get it fixed quickly or you'll end up with a hole the size of your fist in there! that's what my parts car had. gotta find the picture i took of that.......
Old Dec 17, 2004 | 05:17 PM
Morley's Avatar
BUD! Nip it in the BUD!
"nip it in the butt"...I swear, education these days....
Old Dec 17, 2004 | 05:28 PM
305q_ta86's Avatar
Transmission: 5 spd
lol...
Well I cleaned out most of the leaves, and I found no more rust anywhere, and I even checked under the driver front ground effect (that I recently tore on the bottom) and there was no rust either, so I think I'll be ok if I can just take care of this one spot for now...
Old Dec 17, 2004 | 05:43 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
It appears... that it was caused by whomever installed your alarms siren there. They didn't protect the whole that they drilled, and years of driving have taken advantage of their install. Too bad, the rest of the car look pretty good. It's all about preventative maintainance.
Old Dec 17, 2004 | 10:34 PM
305q_ta86's Avatar
Transmission: 5 spd
Yeah, it's tough to tell. I think you're exactly right, Cruzin Kaz.
I dont know much at all about this thing's history, but the interior is SUPER clean, save for some odd rips in the carpet, and the exterior has a crappy paint job, but I dont care. The body's good. I'll have to show you guys a pic of the inside of the RR fender some time.. I think I remember seeing some rust there, as well as in the bottom of the doors, but nothing major. Little grinding and a good coat of paint and most of it should be just fine.
Old Dec 21, 2004 | 12:33 PM
Engine: 383 SBC
LOL, if it makes anyone feel better I still can't read by phonics...
Anyways glad to see you're getting it all worked out now.
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
drumstixer
Sep 29, 2015 03:02 PM
