rear hatch giving me problems
Old Dec 22, 2004 | 08:25 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
My rear hatch has not worked right since ive had the car, its the one that got the motor. Yesterday i open the hatch and shut it again and the motor didnt pull the hatch back down. Im sure others have had this problem, anyone know what i can do?
Old Dec 22, 2004 | 08:29 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
The slides might be broken, or the gear might be busted. Run a search, this has been discussed before.
Old Dec 22, 2004 | 10:03 AM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
Caddillacs used the same motors in their trunks. Worst comes to worst, start looking throught the Junkyards.
Old Dec 22, 2004 | 10:28 AM
GTA4ME's Avatar
Hawks sells the parts you need to rebuild the motor.
Old Dec 22, 2004 | 06:33 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Does anyone know if there is any way that i can get it to go down? It sounds like the motor is not even trying to pull the hatch down. is there any way to disable the motor but close the hatch all the way at the same time?
Old Dec 22, 2004 | 08:11 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
the motor doesnt make any sounds when you pop it/shut it? sounds to me like its just dead... look into buying a new motor assembly from hawks, top down solutions, or even ebay/junkyard. thats the best advice i can give you
Old Dec 22, 2004 | 08:18 PM
Sgt.D's92RS's Avatar
Car: 92 RS
Engine: 305 V8 numerous Mods:
Transmission: Auto+shift Kit 3.73 gears
ditto
Mine had the same problem so I disconected the motor and loosened the bolts that hold the whole thing and lowered the unit down and retightened it lower so when I close the hatch the unit was allready in the down position and would lock down perfectly.
Its like having a regular trunck latch that does not grab and lower it just grabs in a set position. You will have to play with positions to find the right height.
Old Dec 22, 2004 | 09:27 PM
Derth Deboblo's Avatar
Car: '91 Firebird (blown apart)
Engine: *cough*BOAT ANCHOR*cough*
Transmission: Slushbox
Which year Caddy's used the same motor??
-Derth
Old Dec 22, 2004 | 10:14 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Great! thanks alot, i will give that a try, thats all im needing to do really, i never really was to crazy about the pull down motor anyways. Another thing, the key doesnt open the hatch either, the key goes in the hole but it wont turn, anyone know what might cause this.
Old Dec 22, 2004 | 10:29 PM
92RS3.1L's Avatar
Car: 91 Z28
-Derth
Early to mid 90's I believe, Im not sure on the exact year, I'll have to ask my dad what year his Caddy was that had that option.
Old Dec 23, 2004 | 02:37 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
will it turn after a good wiggling, or does it just simply refuse? if its the second case, maybe you need to take it to a locksmith...
Old Dec 23, 2004 | 08:25 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Well i havent really messed with it that much, so i m not sure. But i will mess with it and see what happens
Old Dec 23, 2004 | 09:33 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Also - check the grounds on the motor, and disconnect the motor's power connector and clean the contacts real good. I was having the same intermittent problem and this appears to have been my solution.
Old Dec 23, 2004 | 10:53 AM
Ok, thanks!
-Derth
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
