Complete body work
Old Dec 25, 2004 | 02:16 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
Complete body work
Well im plannin on gettin my car painted, but i already have 2 coats of paint on my car? do i stip it down to bare metal then primer and pain? adn also i have alot of little dings how should i go about repairing those??
Old Dec 25, 2004 | 02:35 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
with 2 paint jobs i would reccommend stripin thru atleast the top paint job. as far as the dings go if they are 1/16 of and inch or less you can grind and fill them you can go up to 1/8 inch deep filler but i perferr not to. if they are deeper than that they will need to be pulled/bumped out.
Old Dec 25, 2004 | 03:46 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
alright then for stripping it could i do it myself? or how much would shop charge? and if i stip at least 1 paint layer off would i re-primer it or what?
Also wats the price range of a good quality paint job at a shop(for future notice)?
Old Dec 25, 2004 | 03:56 PM
Car: 87 Formula
Engine: 350 tpi
depending on the shop i only charge 1800-2200 but im new and im tryin to amke a name for myself a shop would porlly charge upwards of 3k to strip it buy a good dual action sand and some 80 grit 6inch da self adhesive disc and go at her.
Youldl want to go over all the bare metal with a self etching primer or you could go over the whole car with an epoxy primer which would be better then a 2k high build primer surfacer such as k38 from ppg if you have anymore ?s check out the paitn and body link in my sig
Old Dec 25, 2004 | 04:35 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
How much for just a paint job, if i stripped it? also how much would i save if i primerd it and sanded it smooth, and just had them do the paint a clear?
Old Dec 25, 2004 | 11:12 PM
Car: 87 Formula
Engine: 350 tpi
depends on shop/paint color i would charge $600 and paint if it was me but it could be anywhere i dont know best bet is to get estimates most are free get from multiple shops and compare
Old Dec 26, 2004 | 12:09 PM
crazyn8's Avatar
Car: 55 Chevy (the only one that counts), 80 TA, 85 TA, 87 FB
Engine: BBC, BBC, SBC, none
Transmission: M-22, TH400, TH350, none
Keep in mind that if you do the body work and prep, most shops will not touch painting your car; or if they do, they will not warranty the paint.
Another work of advise, before you start primering your ride, make sure you have decided on a shop first, and find out what brand paint they spray. After you find the brand, buy that brand of primer/sealer. There would be nothing worse that a shop spraying paint over non-compatible primer, and the whole paint job lifts, and you have to pay for 2 paint jobs.
Old Dec 26, 2004 | 04:51 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Thanks for that bit, ill have to go talk to soem shops and see if they will let me do the prep work or at least strip it and do the majority of the dings
Old Dec 26, 2004 | 06:58 PM
Morley's Avatar
If you strip it yourself... Tape over ALL of the seams/cracks, remove ground effects, tape around windshield etc. You don't want the stripper getting into the seams because when the car is painted, any stripper you couldn't get out will bleed through the paint, start rust and just plain cause problems.
After stripping you can then remove the tape and sand the remaining paint off where the tape was.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
