Heated Seats In 3rd & 4th Gen's????
Old Dec 28, 2004 | 12:05 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i did a search and couldnt find anything about heated seats... were they an option in 3rd gens? or an option on 4th gens??? i need some heated seats for my iroc that would fit and be heated.... any suggestions? any one ever use any other brand of heated seats in their camaros???? :hail:
Old Dec 28, 2004 | 12:36 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
I am about 99% sure that http://summitracing.com or http://jegs.com sells a kit for this. It converts your normal seats to heated.
Old Dec 28, 2004 | 12:44 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
did a search on both of theirs site and nuthin'...... do u know if 3rd or 4th gens had heated seats? and if their interchangable?
Old Dec 28, 2004 | 01:00 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
I know that on Lexus cars(I work at a Lexus dealership) they use a Peltier system. You say it like this Pel-tee-a. Anyway, it is basically a grid that is grafted into the foam of the seat cushion and has electricity going to it. On one setting it heats, but if you reverse the polarity, you get seat a/c.
Old Dec 28, 2004 | 01:01 PM
paulmoore's Avatar
I almost forgot that you also need some type of fan to blow air through the Peltier element or it won't do squat!
Old Dec 28, 2004 | 01:15 PM
Kandied91z's Avatar
buy a seat heating kit and install it under the leather... it wasn't an option. very nice though as i love it in my gtp.
Old Dec 28, 2004 | 01:17 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i thought i saw your car in a magazine once?? not sure chevy hi-performance i think....
Old Dec 28, 2004 | 01:28 PM
Kandied91z's Avatar
nope not mine....
Old Dec 28, 2004 | 01:30 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
LOL
Old Dec 28, 2004 | 01:42 PM
Kandied91z's Avatar
yes it was september 2004 chevy high performance and my popular hotrodding is out now for the february 2005 issue. thanks for noticing.
Old Dec 28, 2004 | 02:00 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
I installed an aftermarket heater element pad in a stock tahoe seat a few years back. Pretty easy install. And worked very quickly, which is key.
I can't remember the company though.
Kandied: What brand do you have in the GTP?
Old Dec 28, 2004 | 02:08 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ive watched a friend put one on in high school.. i donno the brand.. but it was pretty simple. this heating element goes under the seat cover
then you run the wires under the carpet to the control thingy... and you mount the switch/dial wherever you want it and connect that to the control.. then you give it power and set it to the temp you want it...
it had a bunch of warnings on it about how you could burn your car down, pro install reccomend, ect.... i donno much about it, but i remember it made me nervous.... if i were to get one, i would want one that has some kind of automatic thermal regulator on it... so it cuts off if it gets too hot or if its on too long....
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
yeah, your ride is tight! hopefully my iroc will be like next summer.... if my money is right! so ... does anyone know if 4th gen came with heated seats????
Old Dec 28, 2004 | 02:09 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
nope. it was never a factory option.
Old Dec 28, 2004 | 02:32 PM
Kandied91z's Avatar
GM? they are a factory option in the grand prix.
Old Dec 28, 2004 | 02:33 PM
Kandied91z's Avatar
yeah this was a common problem with the aurora... those things would go and go until you burnt your rear. the one in my grandprix has a resisted regulator that maintains a steady heat after it's reached a certain point.
i've seen the same kits go for 1-150 a seat.
Old Dec 28, 2004 | 02:41 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
will the grandprix fit in the iroc?
Old Dec 28, 2004 | 02:44 PM
Kandied91z's Avatar
i would think so... probably cost you a pretty penny unless you were fortunate to find the equipment at a junk yard. could try it though.
Old Dec 28, 2004 | 03:33 PM
Car: 91RS_92Z28
Engine: 5.0_5.7
Universal and Model specific kits.
http://www.sportsimportsltd.com/heatelcarsea.html
Old Dec 28, 2004 | 03:53 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
there's a windshield repair shop here that'll do it for like $150 a seat.
Old Dec 28, 2004 | 08:39 PM
pskel350's Avatar
heated seats
just ordered these for my truck
Old Dec 28, 2004 | 08:47 PM
AJT86's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
"srdynamics1 Universal and Model specific kits.
http://www.sportsimportsltd.com/heatelcarsea.html "
Look they cant even spell camaro right on there "camero"
Old Dec 29, 2004 | 06:03 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
try these guys out, www.jpcustoms.com
Old Dec 29, 2004 | 07:03 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I was recovering the base of both my seats so I found some heating pads that are going in there. Its not as good as having a heated back as well but it'll do for now.
Old Dec 29, 2004 | 07:54 PM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
I'm saving up for an upholstery job and I was thinking about this too...might as well go one step further and get them with massage =)
Massage and Heat Seats
Old Dec 30, 2004 | 10:56 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
id be alot more intrested in some form of Peltier element system.... liquid or air or whatever....
i donno about you, but most of the time, i would like leather seats to be COOLER... heating in the winter is nice, but leather makes your back sweaty most of the year.... a "AC" seat would be nice.
Old Dec 30, 2004 | 10:58 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i agree mr.dude.... i may have to swipe a pr of luxury seats from the bone yard and get expert in welding to fab the brackets??? sound good???
Old Jan 1, 2005 | 12:20 AM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
Heated seats would be great in a thirdgen, I know I love the heated seats in my Suburban.. :hail: :hail:
Old Jan 1, 2005 | 12:56 AM
nick418's Avatar
Engine: L98, Hemi 6.2
YUP! my mom has a 1998 Suburban, and it has the heated seats to! :hail:
Old Jan 1, 2005 | 01:01 AM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
what about monte carlo seats.. omg their so fcken nice.. heated too
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
