ACC carpet kit
Old Dec 29, 2004 | 11:11 PM
KnightWarrior's Avatar
Car: 1985 Camaro Z-28
Engine: 305 V-8 4BBL (H) Supercharged
Axle/Gears: 3.42 Eaton Posi
ACC carpet kit
Well at 211,000 miles and almost 20 years, I figure the camaro deserves a new rug in it. I ordered an ACC passenger compartment kit wih cut-outs. Anybody put one of these in? I know popping out the seats will be easy, but that damn center console looks challenging. What happens to the wiring, stereo and AC controls when you pull it?
Old Dec 29, 2004 | 11:22 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
i think i might of done it worng but i had to remove the dash partially to get mine out
Old Dec 29, 2004 | 11:31 PM
Damn, that sucks! I don't think you should have to mess with the dash. The console should just lift out from underneath at an angle according to the pictures in the manual.
Old Dec 29, 2004 | 11:40 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
...take the face panel off
... unscrew the radio/hvac
...unscrew the two screws on the underside of the dash on the sides ofthe console up front
...unscrew the ones in in the console compartment
...take off the ebrake handle, 1 screw.
...pry out the U clip on the shifter (towars front of car), slide off handle
... take console out
... it's been awhile since I've had the stock console in my car so I may have missed something, but it's not difficult at all. IMO it's more of a pain to take out the back/side panels.
-Bud
Old Dec 29, 2004 | 11:49 PM
You make it sound so easy. Of course I've wired a bunch of neon and leds, starter kill, back-up switches and crap. Maybe it's time to refine all that anyway! :-)
Thanks for the feedback!
Old Dec 30, 2004 | 12:27 AM
z28kindaguy's Avatar
Car: 2004 Pontiac GTO
Transmission: M12
Re: ACC carpet kit
May I ask how much you paid for the kit?
Old Dec 30, 2004 | 12:32 AM
159.00 from Hawks Third Gen
Hey why do you think your hood is crappy? think it looks cool. Kinda like Mad Max!!
Old Dec 30, 2004 | 12:51 AM
Transmission: M12
Because of this:
Over time the fiberglass flattened out and no where matches the contour of my fenders. Also, the latch is busted so I have to use hood pins to hold it down. Just a very crappy hood.
Old Dec 30, 2004 | 10:47 AM
89firebirdguy05's Avatar
Car: Firebird
Engine: 2.8
Transmission: 5spd
yea..mines just like that..but for the firebird.....and the fiberglass cracks after tiem..so ina few years..its gonna look like spider webs all over your hood..i hate this thing..its sucha pain ithe @$$!
Car: Firebird
Engine: 2.8
Transmission: 5spd
sorry for hijacking! haha
Old Dec 30, 2004 | 03:07 PM
Kandied91z's Avatar
your also going to have to trim the sides slightly as well..
take your time with the center console and make sure you mark the holes for the seat bolts as well as the other recess parts like the holes for the seat belt recievers and such.
if you take your time you'll do just fine. i had to slightly enlarge the shifter hole as well.... actually i had to cut alot out to fit but just work with it slowly removing little at a time. ACC makes great carpet.
measure twice, cut once.
Old Dec 30, 2004 | 05:36 PM
Thanks you have all been very helpful! :-) I can't wait to see it in. My old carpet has worn thin in several spots. I wonder if the new carpet comes with the pad attached.
Old Dec 30, 2004 | 06:24 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
New ACC Carpet comes with the jute pad attached to carpet:
I have a front and rear passenger set, plus trunk area for sale on Ebay: Take a look... plus its cheaper than any other place on the net with passenger and cargo area carpet w/ console cutout. If you want it I will end the auction.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
Old Dec 30, 2004 | 06:25 PM
DTL504's Avatar
Here is another pic:
Old Dec 30, 2004 | 06:26 PM
Kandied91z's Avatar
if you look several posts above yours you'll see that they go for cheaper then what your selling yours. might want to drop the price a bit.
DTL504's Avatar
Trunk Area:
Old Dec 30, 2004 | 06:32 PM
Brock's91RS's Avatar
Car: 87 IROC
Engine: mini-rammed 350
Transmission: WC T-5
Kandied is right...Watch trimming the shifter hole,the console goes furthur down the trans hump on one side,also make sure the front carpet is far forward as possible,B4 you cut
When pulling the top (black plastic) section of the console,make sure the parking brake is pulled up as high as possible,seems to make it easier to get it high enough to remove
Good luck
That ACC carpet fits about as well as anything I've seen
Good Luck
Steve
Old Dec 30, 2004 | 06:42 PM
DTL504's Avatar
Hawks Third Gen Price for $159.00 is for the Passenger Area Carpet Only!
I'm selling the Complete set for 189.00, which include the passenger and Cargo area.
Hawks Third Gen Price for the complet set is $259.00, maybe I should raise the price? I will not do that.....
If you just want to change the passanger area carpet its going to cost $159.00 from Hawks. Complete Set Passenger and Cargo trunk= $259.00
A SAVING OF $69.00, do the math im cheaper..:lala:
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
F-body-fan
Sep 19, 2015 09:02 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
