Can anyone tell me what these are??(Firebird)
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I cant get some of these to light up to see what they are for?
Are some of them just to make it even looking? Or do all of them have a real purpose?
Car: 1983 Daytona Trans Am
Engine: LG4
Some are fake and do not light up,.
There should be a Brake light, Check Engine light, and a Fasten Seatbelts light.
Some newer cars came with a Security light, and Inflated Restraint light.
Some manual cars came with a Shift up light.
Carbuerated cars came with a Choke light.
Transmission: TH200C....700R4
I also have some buttons on my car that I dont know what they do.......I dont have a pic but on the turn signal lever theres a round button on the outside that can be pushed in and have no idea what it does.Also ,on that same lever there is a switch that can be turned left or right,Im thinking its on/off but dont know what it controls .
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The button on the outside of your turn signal lever is for the cruise control (it is the Set/Decel button ... press it with the cruise slider in the middle (ON position) and it will set your cruise at the speed you are going... I you want to stay in cruise control but slow down some, press and hold that button and you will slow down... release it and the cruise is now set at that point)... The resume button (which is the momentary right position on the 3 position slider) can be pressed to increase your current cruise speed by 1 MPH...
Here is what I could find on my 1991 GTA Instrument Cluster...
Left Outer:
INFL
SEAT BELT
Left Inner:
Shift Up
Low Oil Level
Right Inner:
SES Light
Can't get a positive ID on this one, not sure it is filled
Right Outer:
BRAKE
Security
It would be interesting to find out which Firebird ever used the LOW OIL LEVEL light.
Left Outer:
INFL
SEAT BELT
Left Inner:
Shift Up
Low Oil Level
Right Inner:
SES Light
Right Outer:
BRAKE
Security
I had cruise this whole time and didnt know.Now all I have to do is test it and see if it even works!lol
***MOD EDIT***
Please do not try to get around the obscenity checker.
***MOD EDIT***
Car: 1989 Camaro IROC Z-28
Engine: 2002 LS1
Axle/Gears: 3.08
Even the automatics have the shift light it just doesn't function. My TA has it as well as my old Cavalier. I wonder what it would take to make it work as my car was converted to a stick.It would be great if all I had to do was install the bulb or something simple like that.
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
well my car is an auto but the shift lgith works in it but not properly i dont think. well when im just cruisin it comes on when it shouldnt need to shift and when i put it to the floor it goes off when it should be on tellin me to shift and when i aint even touchin the gas it stays off. anybody kno what the deal is?
Originally posted by Spdfrk1990
Haha thats funny did it work.
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
