Center Caps?
Old Feb 7, 2005 | 09:13 AM
johndinu's Avatar
Car: '89 GTA 350 hardtop
Center Caps?
Hi,
I need 4 center caps and I'm considering those HAWKS sells.
I'm wondering if they are any good? (do they have the metal clip?)
Thanks for any input,
John
Old Feb 7, 2005 | 09:15 AM
johndinu's Avatar
link
http://www.hawksthirdgenparts.com/in...il?v=1&pid=835
Old Feb 7, 2005 | 10:15 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I know who would know. Call Hawks: 864-855-2694. For the price I'd suspect they were aftermarket caps, not GM.
These aftermarket center caps are bsing sold on eBay. They don't include the metal retaining ring. In fact they are a bit smaller on the ID and you have to grind some from the ID to use retaining rings.
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Lon
Old Feb 7, 2005 | 10:29 AM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
my only advice would be to epoxy them onto the wheel. Dont know how it is where you live but people constantly steel them by me.
Old Feb 7, 2005 | 10:35 AM
johndinu's Avatar
thx for the replys!
I would guess they would steal mines also...
so if you glue them down they became as hard to steal as the factory ones with the metal clip?
thx!!
Old Feb 7, 2005 | 11:45 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
I wouldn't glue them down, how would you have the wheel balanced?
Old Feb 7, 2005 | 12:09 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
I got these from Andyscaps....search online.
They look good, but they are plastic, no metal clip , just plastic tabs. I'm afraid to take them off now because I'm sure the tabs will break.
I think with some warm weather and if i gently pry the tabs a bit from the inside I can get them off with out breaking. Thats my plan anyway.
Attached Thumbnails Center Caps?-c-documents-settings-pmiddlet
Old Feb 8, 2005 | 01:04 PM
johndinu's Avatar
I know the guy dosen't mention anything about no metal clip, but what do you think about those?
http://cgi.ebay.com/ebaymotors/ws/eB...%3AWN%3AMT%3A1
thx!
Old Feb 8, 2005 | 01:09 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
thx!
Those do have the metal retainers installed on them. (clips)
Old Feb 8, 2005 | 01:13 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Yeah those dont have the metal clip. The metal clip sticks way out. Those could be easily pulled off.
http://members.***.net/andyfrangos/
check those out...looks like the samething to me...plus more expensive....Ebay scares me
Old Feb 8, 2005 | 01:18 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Re-read the above post. The last set to be posted DO have the retainers installed.
Old Feb 8, 2005 | 02:23 PM
johndinu's Avatar
thx for the replys,
I think I'll get those!
Old Feb 8, 2005 | 05:22 PM
johndinu's Avatar
is it just me or those look more like the originals?
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
the chicken under a thick smooth transparent coat?
I never knew how the originals looked like, but I don't mind paying a couple bucks more for a good set.
thx!
Old Mar 15, 2005 | 01:14 PM
johndinu's Avatar
I FINALLY got those (can't wait to receive them).
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7960213395
When installing them, you need to take off the wheel, or you simply push them in from the outside?
Thx for all the advice!!
Old Mar 15, 2005 | 01:42 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
You got it!
Old Mar 20, 2005 | 12:03 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
I have an aftermarket set and their a B--ch to get off. The best way to do it if you're afraid of breaking the tabs is to take the wheel off and gently tap then out from behind.
Old Mar 20, 2005 | 09:20 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
....Ebay scares me
....i assume you never bought there if it scares you, right.
If your smart you'll have 99.99% luck buying stuff of there. Ebay is a great place to get nice parts. Check feedback that is key and read everything in the ad.
Old Mar 21, 2005 | 08:47 AM
Kevin84Z28's Avatar
EBAY can be a real junkyard too. I've had more than my share of parts that were missing things or broken all together.
Old Mar 23, 2005 | 07:00 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
is htere a way to tell if they are original? like a part number or something?
Old Mar 23, 2005 | 10:53 PM
Kevin84Z28's Avatar
You'll know. For one, most of the aftermarket caps have a sticker as the emblem. And the emblems are not high quality. I think that most GM cap emblems were the embossed type. There are no part numbers on my aftermarket caps. GM put numbers on almost everything so why not caps? Theres a guy on ebay who sells the embossed decals for the caps. $14.00 for 4.
Attached Thumbnails Center Caps?-c-documents-settings-dad
gta892000
Aug 11, 2019 11:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
Breazlan
Sep 25, 2015 11:20 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
