custom headliner work
Old Mar 17, 2005 | 12:36 AM
GameRS's Avatar
Car: 1990 Camaro RS t-top, '01 BMW 325i
Engine: L03 V8, 2.5L I6
Transmission: 700r4, Steptronic 5-spd
Axle/Gears: stock, stock
I've been tossing around the idea for a while of embossing the word CAMARO at the front of my headliner. By embossing I mean having the letters stick out from underneath the cloth. I've heard of this done before and was wondering if anybody else has done something like this.
Old Mar 17, 2005 | 12:42 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
I'd get a new headliner board (abs) if you're going to do that. Because the second the fabric peels away from the stock board, its not going to stay back on. But yea, like the idea.
-chillen
Old Mar 17, 2005 | 12:55 AM
GameRS's Avatar
yeah i am getting a new one anyway so I would do it to that one. I'll see if I can photoshop an example.
Old Mar 17, 2005 | 01:28 AM
GameRS's Avatar
ok here is a quick example of what it would look like. I put the word on the back of the headliner just for the pic and would probably put it on the front or maybe even down the middle as I have t-tops.
Attached Thumbnails custom headliner work-d-pictures-cars-my
Old Mar 18, 2005 | 01:52 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
I love the idea i actaully want to redo my liner in black and actually raise the stripe from my roof into it, so basically teh stripe would be raise on the inside to match the painted stripe up top
Old Mar 18, 2005 | 02:14 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
yea, i really like the idea and know exactly what you're talking about. I'm honestly not sure how it will work on the ABS headlienrs, but I know for sure that you wouldnt get the results you want if you use the stock headliner. The second that sheit peals off, its not going back on for any extended period of time.
-chillen
Old Mar 18, 2005 | 07:51 AM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
Sweet idea, might be a bit complicated. If ya do end up trying it, take lots of pix!
Old Mar 18, 2005 | 08:48 AM
86irocboss's Avatar
i want to do flames in mine foming iroc-z inthe flames, do you just get a new headliner board and start filing it away, or what do you use to make the shapes and words under there before you cover it with material??
Old Mar 18, 2005 | 08:57 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Totally do-able. If you keep the stock headliner, make sure to glass it well. As long as the letters were BIG, it would be simple. The smaller they are the harder it will be to look good.
Old Mar 18, 2005 | 10:13 AM
86irocboss's Avatar
glass it well?? what does that mean, how do you do this in the headliner., what do you use to form the flames or words, file or sand maybe?, anyone have a step by step procedure on this/?
Old Mar 18, 2005 | 03:20 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I guess that would make it harder if you were to glass it. You could just paint or vinyl them on then.
By glass I mean use fiberglass to make it stronger and patch it as needed. Factory ones are not strong enough for putting up and taking down more than once.
Old Mar 18, 2005 | 10:52 PM
GameRS's Avatar
I would be getting a new headliner before trying this, definitely an abs one because they are much sturdier. As for lettering, you could use dense foam, or cardboard. I believe there is another headliner post that somebody just brought back from the dead where the guy used cardboard and it looks really good.
Old Mar 19, 2005 | 12:07 AM
Kandied91z's Avatar
if i were going to do it i'd use foam to make my shapes and glue it in place.. easier to mold then the rest.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
