rust inner rocker help!
Old Mar 29, 2005 | 06:24 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i posted a message before, heres a picture of my problem, how would you go about fixing this? i did a search before and found someone who did this exact thing but now i cant find it.
this hole goes outside behind the fender
Old Mar 30, 2005 | 09:25 AM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
a friend and i repaired that spot on a 91' rs once, it was much more gone then yours is, it was a real trick to get to, we ground all that we could out of there and ended up rebuilding the footrest and the side plate near the fender with sheetmetal cut and welded in place, now we need to pull the fender and cut and weld a patch in there as well to make it a complete fix.
be sure to make sure all the factory seam sealer is out, and take your time. i'm sure others will say different then me, but this car was made to be a driver and thats what its gona do.
i have pictures of it somewhere, if i find them i'll post them.
Old Mar 31, 2005 | 05:17 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Is that behind the driver's side fender well? I'm having a hard time telling where exactly that spot is located on your car.
Old Mar 31, 2005 | 07:42 AM
White93z34's Avatar
Engine: LB9
ok, heres the pictures from last year when we patched the 91 rs.
Before
after
welds sealed and painted
finished
Old Mar 31, 2005 | 02:17 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yeah it's exactly like the above pictures, just not as bad i guess it's common for the 3rd gens, i need both sides cutout and welded up
Old Mar 31, 2005 | 04:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
DiNunzio: what did you use to seal the weld? looks like some sort of goop stuff, silicon? then spraybombed?
Old Mar 31, 2005 | 10:12 PM
White93z34's Avatar
Engine: LB9
we used silicone to go over all the welds, i'm prety sure they would have been watertight on their own, but when we has a tube of silicone, why chance it? then just spray bomb primer and silver spray paint. carpet covers it, so we really didn't mind much.
then underneith, we siliconed it again, primered and undercoated the entire area.
Old Mar 31, 2005 | 10:35 PM
jay92,85,79's Avatar
Car: 85z28,
Same with mine but the outer,inner and floor were gone. I would not use silicone it might hold up fine but y chance it. And have to redo it. Get auto seam sealer.or the best would be a expoy seam sealer. I use sem stoff is great and fuser is good. And use a good weld thru primmer.
Attached Thumbnails rust inner rocker help!-c-documents-settings-owner
Old Mar 31, 2005 | 10:36 PM
Car: 85z28,
had to sign it lol
Old Apr 1, 2005 | 08:51 AM
Keith_Indy's Avatar
Car: 87 Firebird Formula
Engine: 305 LG4
Was going to post about this problem over the weekend. Have the exact same problem, just not as bad.
So if I take the fender off I'll be able to get to the back side of that area?
What guage metal would be appropriate for that repair?
Old Apr 1, 2005 | 12:20 PM
Car: 85z28,
U should be able to get to most of it. U allways wanna stay with about the same size metal. I think the piece i used i cut out of a old door.
Old Apr 1, 2005 | 12:27 PM
Keith_Indy's Avatar
Engine: 305 LG4
cool beans...
glad mine isn't that bad. Just a 2 inch x 6 inch or so hole right above the floor seam. Everything else is just surface rust.
Course, the problem is finding the leaks. The matting is wet on both sides of the interior. Have everything but the steering column and heater box tore out so I can do repairs and run speaker/amp wiring.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
tcflint
Sep 27, 2015 05:58 PM
