Small rust spots inside car
Old Apr 9, 2005 | 01:47 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Now say i cut out the small section.. like say 2" x 2". Weld in the nice peice of sheet metal. Now whats next?
What I did to one of the holes i had when i was taking the spot welds out of the back seat bracket. I went alittle to far down and yes went through. So cut a tiny tiny peice of sheet metal. put it in the center, then mig welded around . then grinded smooth. after that i just couldnt get the microscopic pin holes to go away. So i took some body filler. Applied over, sanded. then primered with 2 thick coats. Will that last?
Also is there anything you should do to the underside of the car when you weld a new peice of metal in.
1992rs/ss
Jan 31, 2025 05:10 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
