ACK! flooded interior!!
Old Apr 13, 2005 | 07:38 PM
patricktroyz28's Avatar
Car: 1991 Z-28
Transmission: 4L60
After just a normal rain...the front passenger side floor is SOAKED!
And I don't really see where it is comming from! the T-bars look ok. but I did notice water running on the side carpet "kickplate" under the dash, next to the door.
Happen to anybody else..where should I start?
Old Apr 13, 2005 | 08:13 PM
tagta1's Avatar
Three likely possibilities.First and most likely it is running down from the t-tops through the "A"piller and ending up on the floor.It could also be coming in through the cowl or firewall somewhere but that doesn't happen very often.Or possibly through a door seal.Most likely through the t-top though.Get out the garden hose...Don't waste any time getting around to finding it or you will find yourself with no floor.
Old Apr 14, 2005 | 04:28 AM
Car: 1991 Z-28
Transmission: 4L60
Tks..i will check it out today!
Old Apr 16, 2005 | 08:28 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
i have the same problem.... is coming in right where the little triangular piece is next to the mirror and where that meets the seal on the a pillar....
Old Apr 23, 2005 | 09:40 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
another area to check is the firewall area just below the windshield. if you look on both sides, you'll see all that sealant around there and if it's all dried up and cracked, you'll leak in there, too. if that's the case, i suggest chipping all the old stuff out altogether and replace it with new. that's what i did, and resealed the lip of the firewall, too. makes it a lot easier if you take the hood off, but that's up to you.
KAM
Old Jun 6, 2005 | 07:03 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
same problem here
Old Jun 6, 2005 | 07:05 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I got a car cover when the heavy rains are coming. I'd like to fix the tops eventually though.
Old Jun 6, 2005 | 08:05 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
Off the subject though, Man you got one fine car!
RyanJB
May 7, 2016 06:23 PM
Zane Story
Oct 8, 2015 12:40 PM
codeysabatini
Sep 20, 2015 11:36 AM
MORREALE5
Sep 13, 2015 09:01 PM
sylentnite
Sep 9, 2015 02:55 PM
