headliner
Old Apr 22, 2005 | 03:34 AM
Kandied91z's Avatar
headliner
is there any replacement headliner that doesn't have this part? is just smooth with no indentations..
Old Apr 22, 2005 | 05:26 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hey, when i was looking for a new one, i could not find one without that, i went to the junkyard and got a decent back board out of a 91 for 30 bucks, i then recovered it, looks great!
Old Apr 22, 2005 | 01:47 PM
Kandied91z's Avatar
thanks for the input but i don't have that option.. i'm considering just making the board as that's alot of money for the piece above to have to do more work to make it look factory...
Old Apr 22, 2005 | 08:08 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
what option? i bought a used factory one and recovered it.
Old Apr 22, 2005 | 11:00 PM
Kandied91z's Avatar
so no-one has an aftermarket headliner without this indentation?
Old Apr 24, 2005 | 11:57 AM
BOTTLEDZ28's Avatar
Transmission: A4
I think my 1A Auto one was flat all the way around. I know I had to cut a hole for the interior light. I will have to look at it tomorrow.
Old Apr 24, 2005 | 04:10 PM
Kandied91z's Avatar
could you please check because the only one i found on their site is the one i posted above.
Old Apr 24, 2005 | 09:57 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i'm looking for the same thing i don't like the ridge.
Old Apr 25, 2005 | 04:16 PM
Kandied91z's Avatar
no one has an aftermarket abs headliner without this indentation???
Old Apr 25, 2005 | 04:29 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
o crap all aftermarket ones are like this , if i have to get a new one i dont like that indentation either, i want a flat one too . that sucks if their all like that .
Old Apr 25, 2005 | 04:34 PM
Kandied91z's Avatar
that's what i'm trying to find out.. i've searched and it hasn't been mentioned. please someone tell me if they are all like this or if they make flat ones as well.
Old Apr 27, 2005 | 03:28 AM
ASUspeeddemon's Avatar
Car: '86 Firebird
Transmission: th350
You might wanna check these guys out. The picture is kinda ****y and i'm not sure if it has the indentation or not but it couldn't hurt to check 'em out.
http://www.fbodymotorsports.com/inc/pdetail?v=1&pid=283
Old Apr 27, 2005 | 02:22 PM
Kandied91z's Avatar
yes it does..
thanks for the suggestion though, anyone else?
Old Apr 28, 2005 | 10:48 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Why can't you recover a stock one? It sounds like it's the only way you're going to get what you want. Recovering a non t-top headliner is a piece of cake.
Old Apr 28, 2005 | 11:16 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
just got a 1aauto a little ago, its got that indentation in it.
-chillen
Old Apr 28, 2005 | 03:46 PM
Kandied91z's Avatar
because i can't find one in good shape here in my area and mine has the rear corners torn off. if i could get a good board to start with i would.
Old Apr 28, 2005 | 10:56 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Just give in and buy a console to cover it.
Old Apr 29, 2005 | 09:25 AM
Jim85IROC's Avatar
A damaged board can be repaired pretty easily. The one in my 86 actually had the rear corners break off when I removed it, so I used glue-soaked burlap to reinforce it. It worked great, and was not visible once it was recovered with new material.
Old Apr 29, 2005 | 04:40 PM
Kandied91z's Avatar
thanks for the tip.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
PurelyPMD
May 5, 2016 04:57 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Sep 8, 2015 10:36 PM
