A/C delete Block Off
Old May 2, 2005 | 08:08 PM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
I need some pictures from people who have done this before. I dont want to pay 100 dollars for a ac delete box so was thinking of just riviting a piece of sheet metal over the hole.
I would like to see some pictures to see how it looks. And did you guys put rtv silicone around the edges to prevent water from comming into the interior. Thanks.
Old May 2, 2005 | 09:17 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
You cant find a A/C delete up where u live. Im surprised any canadian model even came with A/C.
Old May 2, 2005 | 10:02 PM
Every Wrecking Yard around here don't even have a camaro in the yard.
Old May 2, 2005 | 10:07 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Well im screwed too down here in texas all the cars came with A/C so its hard to find deletes. And i also dont want to pay a 100 bucks for it.
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Here's mine. Wasn't really all that difficult to make. I basically just used some galvanized steel I had. I took out of the AC evaporator, cut out the basic shape with a dremel tool, drilled holes to use the stock screws, cut a hole for the blower resistors, bent it, finished the edges and sanded it down, painted it with high-temp paint, put some light silicone on all the mounting surfaces, and bolted it in.
I like it just for the fact that I can reinstall the AC if I ever want to.
Old May 4, 2005 | 09:24 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I have a secret, S10s used the same thing. Not sure on the years, but there are a ton of those vehicles floating around as well.
Old May 4, 2005 | 05:38 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
just went to the boneyard and pulled on off a 86 S10....
Cost $15.00 which included the fan motor..
Old May 6, 2005 | 09:47 PM
Thanks For that Little secret.
m00n420
Sep 11, 2015 02:39 PM
buckshot63
Sep 10, 2015 09:15 AM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
mantaguy
Sep 2, 2015 10:42 PM
